3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Make A Custom Fancy Walking Cane
Step 4Remove Excess Wood on Shaft with Hand Tools.
Remove shaft from drill press clamp and return to the Band Saw.
On the Band Saw, follow the line you marked from the top to bottom, tapering to 7/8" wide and trim off the excess wood that will be the bottom of the cane shaft. This step helps eliminate excess wood that would otherwise take longer to remove.
[Note: It is always best to remove LESS wood and go back and remove more. You can not easily add wood if you've taken away too much.]
You can now begin to remove more wood to shape the shaft. You can use hand tools and/or power tools. Which ever are available. I am showing you how to use both.
This is a Shaving Mule. It is an old fashioned system to clamp and work on a piece while sitting. You can make your own or buy one. Your right foot kicks the foot stand to create pressure on the jaw to wedge the piece you are working on in place. This is used mainly to make spindles for chairs.
Using several different styles of spoke shaves and rasps, I taper the shaft down to the desired shape and thickness.
Do not do the final shaping at the joinery end, as you want to assemble the handle and optional collar before your final shaping. Otherwise you may remove too much material and have an unsightly void.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:mmh
I love creating art and functional art is a challenge that I am enjoying by creating one-of-a-kind canes and walking sticks, as these can be stylish along with functional and also comfortable to use. ...
more »
