Step 7Adding a Collar to the Handle & Shaft (optional)
Select a piece of wood at least 1.5" x 1.5" x .5"-1.0" Thick. Any smaller and you will have difficulty holding it in place while drilling. You may still want to use a hand clamp to hold the wood, as when the drill is in the wood it can spin and you will lose control of your grip. If you drill the hole in a larger piece of wood and then cut with the band saw, this will eliminate this problem.
Add Comment
