How To Make A Dvd Laser by mole666
video How To Make A Dvd Laser
I used the same model as in my other videos a LG 16x DVDRW. Used an Axiz Housing powered by two AAA batteries This is how i did it
1-40 of 41Next »
knex luver234 says: Apr 11, 2012. 6:53 PM
it has to be a burner, rewriters wont work either, your can find the diode on the net cheap, thats what i did and it works wonders! there is actually a kit on ebay that works also
monkeys98 says: Sep 25, 2011. 1:04 AM
will one from an ordinary dvd player work
yaly says: Apr 9, 2011. 2:05 AM
hey i got mine from an old cd reader/writer it is 20x it has a ribbon cable on it and when i plug it in it makes a high frequency sound and lights faintly red i tried to see if it is infra red with a digital camera but i makes no diffrence
PerfectPantaloons says: Mar 10, 2011. 7:53 AM
Does it have to be a CD/DVD burner??? i have a Portable CD Player, would that work?
Sandisk1duo says: Mar 21, 2011. 2:08 PM
Has to be a 16x DVD Burner
iApple guy says: Mar 14, 2011. 4:04 PM
Do you a burner diode.
bjornacorn says: Aug 9, 2009. 1:15 PM
I have dial-up, and it is HORRIBLE to live with dial-up. Can u put it in word form, and pics.
Data643 says: Aug 5, 2010. 6:59 PM
I feel so bad for you. Yay for Ethernet and WiFi!
omnibot says: Dec 20, 2009. 5:36 PM
Meh .. films been removed from Metacafé :(
bjornacorn says: Aug 9, 2009. 1:12 PM
Do DVD players work?
walmzdawg says: Jun 23, 2008. 10:22 PM
cna you use a laser taken from a ps2?
Madrias357 says: Jul 13, 2009. 6:07 PM
probably.
Madrias357 says: Jul 13, 2009. 9:48 AM
Well, I got my Sony 18X laser diode. Can't wait to put it to 'good' use.
Mr USB says: May 17, 2009. 11:54 PM
do you have to use a axiz laser.
Mr USB says: May 17, 2009. 2:57 AM
mole,can you use a diode from a dvd reader and the diode looks like this...
moosey94 says: Nov 23, 2008. 1:30 PM
hey i am kinda new to this sorta stuff and i have just took the optical assembly out of my old CDRW drive and there is a focusing mechanism. should i take this apart for the diode or should i leave it as it is?
Mr USB says: May 17, 2009. 1:10 AM
yes. the focusing mechanism is for the diode
freakinhuge says: Feb 8, 2008. 9:52 AM
Mole, How did you get the laser diode out of the cast metal piece it was in (from the DVD Burner). I got it down to the diode and the mount for the diode, but it seems to be epoxied in there pretty good. Any help is appreciated.
Mr USB says: May 17, 2009. 12:54 AM
very carefully cut the case using a haksaw. try not to damage the diode.
mole666 (author) says: Feb 8, 2008. 4:43 PM
I used surface mount tweezers to pick it out.. But by the looks of yours you could get two pliers and try to break the heat sink, I have done this before. But be Very careful
drummonkey92 says: May 27, 2008. 8:35 AM
i've got the same problem, i keep trying and can't get the diode out of the heatsink, can anyone offer any detailed advice or post a video or something? thanks
Sagar Gondaliya says: Feb 15, 2009. 10:50 AM
you could try to use a dremel. I used mine and it works great. use a grinding bit and grind away the heatsink. it tales longer but is less dangerous for the diode.
deth2all says: Jun 1, 2008. 12:30 PM
wouldn't the benefit of a heatsink be a good thing??
drummonkey92 says: Jun 2, 2008. 8:59 AM
i think you need to get the diode out for it to fit in the module (which has it's own heatsink i'm guessing)
scanna says: Jan 28, 2008. 9:51 AM
Hello and thank you 4 this vid. I just opened a 20X DVD burner from LG, and i found 2 diodes. One has the open can, the other is a closed TO5 or something similar. I don 't know wich one is the burner !!! Anyone could help me ? TKS all !!!
Sk8erboy12192 says: Feb 24, 2009. 7:29 PM
i bought an hpo 22x with lightscribe, and my open can diode was the red one, and extremely strong, and i used an infrared cam to check the other 1(the closed can one) and it was infrared, but thne open can one only worked with the top piun, and the middle pin, the bottom pin did nothing, im not sure why,mabe the configuration of it, bbut it could easily go either way with the open or closed
mole666 (author) says: Jan 29, 2008. 12:29 AM
The open diode will be the infrared.. Totally invisible to the human eye and VERY Dangerous. The closed one will be the one you want..
el eliel says: Feb 22, 2008. 2:23 AM
yes please be very careful about IR lasers. you will hear me always talking about safeties and legalities til you barf, but IR lasers are especially nasty. when you surgically burn your cornea and/or permanently destroy your retina, do not ask me to be an eye donor. but then again, it's kinda funny to burn meat with one...
the1andollieollie1 says: Jan 8, 2009. 2:28 PM
is the IR laser that power full ??? ( i like that ) :) this laser on the vid. is awesome i did it with a diode from a high power computer drive i used it to licht fireworks on the 4th of juli from 8 yards away!!!!
el eliel says: Jan 20, 2009. 1:19 PM
yup. it's kinda also that your eye is a jelly filled optical device embedded in a meat and bone casing. like if your binocculars had a ham case. and don't think your sunglasses will protect you. welder's glasses/laser specific glasses are what you need.
scanna says: Jan 29, 2008. 1:22 AM
thank you mole. Have a nice day!
cybsn says: Jan 10, 2009. 11:51 AM
Could i use an other laser for the module? For example a green 50mw laser or a cheap 3euro red laser? And finaly could i mod the 50mw green one to power it up?
panstar1 says: Nov 8, 2008. 9:20 PM
I have just removed laser diode from the optical assembly. I have tested it with two AA's & a 100 ohom resister in series just for safety ,so I don't burn it out ( I did try this on another diode so I know it will work) ,I got mine from a hp dvd-rw . I wasn't ready to do this to the lg dvd-rw , (I got both for cheap ) ,but I got the diode out by carefully removing it from the optical assembly & carefully cutting through the heat sink on both sides & snapping it apart. if you are careful it will come out intact.
budsiskos says: Aug 25, 2008. 5:03 PM
could you do this with a 20x dvd drive
azn_kid129 says: Jun 9, 2008. 11:54 PM
hey i need help here. I'm just new at this laser thing and i dont know what a diode is. can you help please. i have one on those $10 red laser and dont know how to make it burn or cool.... help please
rocketresearch says: Jun 19, 2008. 11:51 AM
a diode is the actual laser part of it. take the diode out of the regular red laser that you have and replace it with the DVD diode.
turner22 says: Apr 7, 2008. 2:30 PM
what is the axis laser? can you find it inside the dvd player?
drummonkey92 says: May 27, 2008. 8:32 AM
its not inside the dvd player, i think its a module to power the diode. if you google 'axiz laser module' you'll probably find one
keltinator.com says: Feb 8, 2008. 7:20 PM
(removed by author or community request)
mole666 (author) says: Feb 9, 2008. 7:30 AM
1-40 of 41Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
