Introduction: How to Make a Fishtail Survival Bracelet
About: I have a great passion for cooking, crafting, fixing, or building stuff!
Throughout this Instructable I will be demonstrating how to make a fishtail style survival bracelet. Take your time as it can get a tad bit confusing at points. My survival bracelets are all designed so they can be deployed easier, and don't involve melting the ends to the bracelet. That reason alone makes "ending" the bracelet a little harder then most other tutorials where they simply have you melt the end and press it into the bracelet (I hate that!). What's the point of doing that? When you need to unravel your bracelet, your don't want to have to rip that thing off.
I also run a small online boutique called Rusticlub
KEEP IN MIND
When following this Instructable, the numbers in the instructions coincide with the numbers in the diagram.
Step 1: What You'll Need
What you'll need:
Step 2: Measuring Your Wrist
1. Wrap a string, cord, or small rope around your wrist. Make sure it is very snug. Not overly tight, but do not make it loose.
2. Take a marker and draw a line across the two crossing cords/strings.
3. I've darkened my lines in photoshop to demonstrate what it should look like in this step.
4. Now measure from the first line to the second line.
In this example my wrist measure around 8 inches. So when I go to measure for my bracelet I'm going to add 1 inch to that measurement. This will be further explained in steps to come.
Step 3: Melting the Ends
1. Take your lighter and melt the ends for 3-4 seconds.
2. With your fingers (you may want to wet them or lick them) or a pair of pliers squeeze the melted end to form a nice, thin end.
Step 4: Completing the First Cow Hitch
Throughout this step you will make a cow hitch on the male part of the Side release buckle. Follow the numbered instructions below which coincide with the numbers in the diagram.
1. Fold your cord in half so the two ends meet. Place both ends through the cord like shown in the diagram.
2. Place the two ends back through the loop created in step one and pull 1 of the cords through until the knot is tightened.
3. Adjust the cords so one cord is hanging out about 1 inch, and the other one is the rest of the cord like shown in part 3 of the diagram.
Step 5: Making Your Second Cow Hitch and Making Your First Measurement.
1. Take the long piece of cord you have left and place it through the female part of the buckle like shown in part 1 of the diagram.
2. In part 2 of the diagram you are going to make your first measurement. You will have to "double check" your measurement this exact way after you are done with the second cow hitch. Line your ruler/tape measure up with the middle of the male buckle and adjust your female buckle part so it lines up with the measurement you got in step one. Remember to add 1 inch to the measurement you got in step 1. If your wrist was 7 inches, you will want the female part of the buckle in this step to line up with 8 inches on the ruler/tape measure. My wrist was 8 inches in step 1, and in part 2 of this diagram my measurement goes to 9 inches (it's hard to see sorry).
3. Now take your loose cord again, and come back up through the female buckle. This is going to seem like your canceling out or pulling the cord back through the buckle.
4. Pull the cord through until you are left with a little loop like shown in part 4 of the diagram.
Step 6: Completing Your Second Cow Hitch and Re-Measuring
1. Like shown in part 1 of the diagram, place your male part of the buckle through the loop created in step 4.
2. Now place the loose cord through the same loop.
3. It should now look like this.
4. Pull everything tight and you should have your second cow hitch.
5. Adjust everything again so it all lines up with your measurement in step 4. Measure again in this step to insure you still have the correct measurement.
Step 7: Weaving the Loose Cord Through the First Cow Hitch
1. Take your loose cord and weave it from underneath the male buckle part, through the middle of the cow hitch.
2. Now continue the loose cord underneath the "loop" part of the cow hitch. Part 3 of the diagram shows this a little better.
3. A better angle of what we are trying to achieve in this step.
4. Pull the loose cord through all the way until it's all nice and tight. It should look like part 4 of the diagram.
FINALLY! Now your loose end of the cord is ready to braid the bracelet itself.
Step 8: Starting Your Fishtail Braid
When braiding the bracelet we will call the two cord that are running from top to bottom the "core cords" the on on the left will be core cord 1 and the one on the right will be called core cord 2. These are the cords you will be braiding around AKA the "core" of the bracelet.
1. This is what your setup should look like.
2. Take your bracelet cord and wrap it around the back of core cord 1 and up through the middle of the two core cords.
3. Tighten your cord up and prepare for second weave.
4. Continue the loose cord around the back of core cord 2 and up back through the middle of the two core cords.
5. Tighten your braids again.
Step 9: Continuing Your Fishtail Braid
  • When braiding the bracelet we will call the two cord that are running from top to bottom the "core cords" the on on the left will be core cord 1 and the one on the right will be called core cord 2. These are the cords you will be braiding around AKA the "core" of the bracelet.
  • You are going to repeat step 7 now. We will demonstrate the braid one more time in this step then you're on your own until you get down to the bottom!
1. Weave your loose cord under core cord 1 and up through the middle of the two core cords.
2. Tighten your braid.
3. Weave your loose cord under core cord 2 and up through the middle of the two core cords.
4. Tighten your braid. ALSO: Part 4 of the diagram shows you the the "break down" of the weave that your are doing. It's pretty simple. You are simply weaving in and out, in and out.
Step 10: What It Will Look Like and How to End
1. This is what it will look like half way down.
2. End like this once you get down to the female part of the buckle.
Step 11: Ending and Tying Off Your Bracelet
Take your time on this step it can get a little confusing.
1. Take your loose cord and wrap it underneath both "core cords".
2. Continue the loose cord through the middle of both "core cords" on the top.
3. This part of the diagram shows you what it should look like. Follow the "blown up" part of the diagram for an easy to follow image. The weave is shown by using numbers starting with 1 and ending with 5.
4. This part of the diagram shows you what the underneath side should look like. Notice the numbers 2, 3 and 5.  Numbers 2 and 3 form a loop underneath on the inside of the bracelet which you will use in the following step.
Step 12: Ending and Tying Off Your Bracelet Part 2
1. Pull the loose end through the loop created in the previous step.
2. Pull everything nice and tight and prepare to cut the excess cord.
Remember to make sure it's nice and tight before you cut the excess cord.
Step 13: Cutting and Melting the End
1. Cut the excess cord leaving roughly 1/4 of an inch.
2. This is what it should look like before you melt and form it.
3. Use your lighter to melt the end for roughly 3-4 seconds or until all the frays are gone. Using your fingers or some pliers squeeze the end so it forms a nice, flat end. Remember this is going to be against your wrist so you don't want a sharp or bumpy end.
4. This is what it should look like when done.
Step 14: You're DONE!
Enjoy!
