How to Make a Hexafish Rubber Band Bracelet (with a Fork)
294,208
34
8
Published
Introduction: How to Make a Hexafish Rubber Band Bracelet (with a Fork)
Step 1: Materials
You need :
-rubber bands
-S or C clip
-fork
-pencil (optional)
I'm using purple and green
Step 2: First Step
Grab your fork and your first rubber band (mine is purple) slide it through the first bristle, pull and twist,
then put over second bristle, pull and twist,
put on third bristle, pull and twist one last time and put on the last bristle
You should see what seems like two infinity signs
Step 3: Second Step
Repeat what you did in the first step with the next color (mine is still purple)
Step 4: Third Step
Take your pencil (or you can do it with your finger) pull the first bottom band and put it over the first bristle
Pull the second band on the bottom and put it over the second bristle
Pull the third band on the bottom and put it over the third bristle
Pull the last band on the bottom and put it over the last bristle
Step 5: It Should Look Like This
Step 6: Repeat
Repeat steps 2-3 until desired length you should start seeing the pattern after the first could bands
Step 7: Be Sure to Pull
I've sure to pull the back every now and then to see the pattern better
Step 8: Putting on the Clip
While pulling the back you should be able to see two open bands pull and put through one side of the S clip
Step 9: Finishing Up
After reaching desired length be sure to grab all four bands from the fork put them all together and slide in the other side of the S clip and there's your Hexafish Rubber Band Bracelet
  • Oil Contest
    Oil Contest
  • Backpack Challenge
    Backpack Challenge
  • Stick It! Contest
    Stick It! Contest
8 Discussions
Thank you very much! I love this bracelate!
This is a chevron, or quadrafish, not a hexafish as a hexafish has 6 sides and this bracelet has four. sorry, but, possibly to reduce readers confusion change the name.
Picnic and forgot your loom? Fork, a good metal one within arms reach and clean? Get the rubber bands out and start workin it up at the picnic site!
made it .......very proud of myself and thanks for all the help you all gave
Great use of a fork! Such a smart idea, and the results speak for themselves. Thanks for sharing.
