I originally built this to power a small coil gun but it can be used for whatever you need it for.
It runs off 3.3 volts but it will run off of 2 "D" size batteries with a reduced voltage output and slower charge times. The parts can be purchased online for about $20.
I recommend running it off an old computer psu. The one I use to run it is rated to 16 Amps on the 3.3 volt line and it runs this fine.
For instructions to make the 3.3v power supply look Here
Remove these ads by
Signing UpStep 1Warning!
This energy is stored in capacitors and it will still have power in it even when unplugged.
It is capable of putting out several amps! The output can easily be deadly!
DO NOT BUILD THIS UNLESS YOU ARE FAMILIAR WITH THE SAFETY PRECAUTIONS FOR WORKING WITH HIGH VOLTAGE
You are responsible for anything you do with this.
You should make certain that the device is clearly marked
Here is the warning for this device
High Voltage Warning Sign - for gimp
High Voltage Warning Sign - for photoshop
Here is the font I used on the warning signs above.
Helvetica-Black-SemiBold.ttf
I am making a charging circuit for a coilgun, but i accidentally bought non polar caps. I was wondering if i could still use these with some sort of circuit adjustment, or if i need to purchase all new polarized caps? Can you help?
Non polarized caps will work. They are larger than polarized caps though. With them it doesn't matter which direction you hook them up.
My current version has a flyback with a 15 turn primary and a 400 turn secondary.
I used 22awg on the primary and 28awg on the secondary.
It charges to 380v in about 10 seconds with a 13.8v input (could use a zvs driver for more power).
I need to get some high speed diodes to rectify the output. I have been using 1N4007's but they are too slow. I will get some UF4007's instead.
The charging boards are not available or the link is incorrect. Do you have a part # for the charging boards or a suggested replacement for this part if the ones you suggest are unavailable?
Thank you.
Ahimsa.
I am working on a better power supply that doesn't use them, but I've got a lot to do before I can make the instructable.
thanks alot.
