3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Make A High Voltage Power Supply
Step 2Parts & Tools
The Parts Needed
Charging Boards
I used 8 Boards but order a few extra in case you mess up on one.
Charger Boards - Electronic Goldmine
Unfortunately Electronic Goldmine is sold out of the charger boards. I don't know if they will get them back.
However I have been working on a bigger and better power supply, it won't be done for a while though.
Capacitors these should be rated to 400 Volts minimum and a total of 2000 - 3000 uF.
Electronic Goldmine is currently out of the ones I used.
Capacitors - All Electronics
Capacitors - Ebay
Switches (2) 15 Amp minimum rating
Alligator Clips or Binding Posts for HV out (1 Pair)
Small wire for soldering to charging boards (22AWG Solid)
Heavy wire for power in & out (18 - 16AWG)
Tools Needed
  • Soldering Iron and solder
  • Hot Glue Gun and Glue Sticks
  • Wire Cutters
  • Wire Strippers
  • Nedle Nose Pliers
  • X-Acto Knife
  • DC Volt Meter (optional)
4 comments
May 25, 2010. 5:03 PMbrooklynlord says:
Can you post a schematic if you can so we can still build it without the board? Thanks.
Mar 22, 2010. 3:21 PMh8redflip says:
Hi, do you have a new link to a charger board, as that one has expired, or any specifics to look out for? thanx :)
Jan 20, 2009. 5:37 PMjunits15 says:
oh i was under the impression that you add up the voltages of the capicitors, I did not know that you are only supposed to add up the capicidence. :P
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
37
Author:rocketman221
I enjoy building electronics & robots. I like building computers as well as writing programs & web sites. I like to build and launch rockets. I especially like to play with high voltage power supplie...
more »
