How To Make A Jacobs Ladder
 by fatboyslim
This instructable will show you how to make a fully working Jacobs Ladder.
You may have seen Jacob ladders in those old Frankenstein movies where you see electricity travelling up two wires disappearing then re appearing at the base of the ladder.
WARNING: This project uses HIGH VOLTAGES which can kill you. I wont say don't try this at home as it is a fun project but be EXTREMELY careful.
Also This is my first INSTRUCTABLE.
Please feel free to leave comments.
kdbacho says: Jan 21, 2012. 6:33 PM
will your transormer work if it says "secondary ground fault protections"
clevelandstorms in reply to kdbachoJul 25, 2012. 7:00 AM
my transformer was made in 1999 so it should have the secondary GFI. all I know is that when i touched the high voltage lead to any other object besides the other bushing or the ground wire it tripped the circuit
A.C.E. in reply to clevelandstormsOct 17, 2012. 7:08 PM
I just got an old transformer from a heater unit that broke in my house.. It's a 17.5 Kv transformer, but im not sure of the mA number, I can't wait to make one of these! haha or maybe I will try to make the plasma speaker also on instructables
o0JohnnyReb0o says: Aug 31, 2009. 5:41 AM
you say that they will give it for free if we say it's for a jaccob ladder but I said it and the womand looked me strangely and asked me why I would like this then she said me it cost 140 euro...
sspence in reply to o0JohnnyReb0oJan 15, 2012. 7:19 AM
For a used one?
jpoopdog says: May 31, 2011. 3:24 AM
12,000v@0.03A = 360 watts
this thing will take quite alot of power,
are you sure it outputs 30ma?
and doesnt just take in 30 ma?
sspence in reply to jpoopdogJan 15, 2012. 7:18 AM
Transformers are about 96% efficient, so there's not a lot of difference between input and output.
Einsteins Circuitry says: Jan 12, 2008. 2:00 PM
I'm surprised that they gave you the transformer for free. Where did you go?
PS: Nice Instructable. +1 and favorited
fatboyslim (author) in reply to Einsteins CircuitryJan 12, 2008. 9:06 PM
A place called Neon Supplies in New Zealand
Einsteins Circuitry in reply to fatboyslimJan 25, 2008. 7:08 PM
Yay! I just found a small store that was willing to give me one for free! only 9kv but still! I'm glad I didn't buy one on ebay.
sspence in reply to Einsteins CircuitryNov 29, 2011. 10:23 AM
Oil furnace repair shops may give you free OBITS. I have a pallet full of OBITS that were on their way to a dumpster.
Everfalling in reply to sspenceJan 15, 2012. 3:35 AM
what's an OBITS?
sspence in reply to EverfallingJan 15, 2012. 7:16 AM
oil burner ignition transformer's
Alex1M6 says: Dec 31, 2011. 8:59 AM
Like mine?
1stcontact says: Jul 31, 2011. 11:44 PM
Does the diameter of the rods matter to the output of the transformer and can I place a plexiglass tube around the rods for safety? Oh also does it matter what metal the rods are made of?
fatboyslim (author) in reply to 1stcontactAug 1, 2011. 12:37 AM
Not Necessarily. But bear in mind that if you use rods that are too thin, then it may have the possibility of melting. Yes you can put a plexiglass tube around it, and it shouldn't affect its performance. Nope it does not matter what metal you use. I had used steel in my one
history323 says: Feb 3, 2010. 2:18 PM
"guaranteed to impress family member'
Haha i would probably get kicked out of the house.... But cool instructable I will try it anyway!
imgod22222 says: Jul 3, 2008. 6:19 PM
What would you say is the max/min current you'd want for this project?
fatboyslim (author) in reply to imgod22222Oct 11, 2008. 2:47 AM
Roughly between 20-60milliamps. Anything more than that would be overkill.
chriskarr in reply to fatboyslimJun 25, 2009. 7:24 AM
I wouldn't say over-kill, the larger the mA rating, the wider the arc can grow to be. If you have two, try to put the primaries in parallel and the secondaries in parallel on two transformers that have the same voltage rating. This will add their mA rating and keep the voltage rating the same. But, they MUST be the same voltage rating, even if not identical. I have a setup, right now, with one modified Franceformer (I modified it by removing the GFI unit) 9KV/60mA NST in parallel with one 9KV/30mA NST, essentially giving me 1.5X the power I had before. My arcs don't start at a much closer distance, however, the arcs do pull to a much longer distance. The 10KV/cm is the rule for starting the arc, but after that it's the current of the transformer that keeps the arc going. If you do try what I recommended, I also recommend a variac to ramp up the power to 0.5 input power, if possible. If this isn't possible, I suggest just plugging it in normally. If you end up with a transformer that won't arc from one side to the other very well, you probably don't have the transformers in phase. Switch around the primary connections on one of the NSTs, and you're all fixed. If you'd like to know more, PM me.
cowboy4884 says: Jun 19, 2008. 11:15 AM
Ive made different jacobs ladders using different transformers ranging from 7.5 KV to 50 KV. They all work basicly the same just a fatter arc as the voltage goes up. Ive always wanted to put together a jacobs ladder that would arc 5 to 10 foot accross. Any Ideas?? Ken
fatboyslim (author) in reply to cowboy4884Jun 19, 2008. 9:28 PM
Well, to have a five foot arc you will need at least 1,500,000 volts. Because air breaks down at 10000volts to every centimeter. Five feet have 150 cm so you will need a MASSIVE POWERSOURCE. I have made a tesla coil with registers at 500,000volts. The only way you can reach that type of voltage is if you link IN SERIES lots of the SAME neon transformers or those 50KV transformers you have. You will need alot of them though.
chriskarr in reply to fatboyslimJun 25, 2009. 7:16 AM
You can't link NSTs in series, since they have the center-tap on the secondaries. It makes things horribly inconvenient for guys like us, but they make it cheaper to make the NSTs for companies like Franceformer. If you need to link transformers in series to get a high-power supply, I would recommend MOTs ran off of a 220 source with a high-potential step-down transformer to bring the voltage down to 110/120V (If your microwave was made for 120, that is). This will allow you to have a higher output power (in KVA or KW) on one circuit. Parallel the MOT primaries, series the MOT secondaries and pray to God that you don't kill yourself on the exposed cores. Then, hook it up after the stepdown transformer and there you will have it. A 1A however-many-KV-you-decide-it-should-have power supply. I recommend going for 100 MOTs in series. That would definitely be a world record and would give you 200KV...Although I do suspect that you might have insulation issues at that point. Why not just get an X-Ray transformer rated for 100KV and put in an external series resonant capacitor? It will pull more current, so you'll also need a PFC cap (Power Factor Correction) to prevent this and maintain the lifespan of your transformer. As the previous comments have made note to, you're probably better off building a Tesla coil out of your NSTs that are under 20KV and, preferably, over 10KV. If you have any with 60mA ratings, that would be better, as you double your power consumption right there.
technodude92 in reply to fatboyslimOct 10, 2008. 7:49 PM
that has it's limits though. you can't pump 10kv into a neon sign transformer primary and expect it to survive for long. You're probably better off building a tesla coil
fatboyslim (author) in reply to technodude92Oct 11, 2008. 2:44 AM
Technodude92 is true. It would be better to build a tesla coil .In fact i have built a tesla coil. They are incredibly fun to make. I will soon put up an instructable to make a tesla coil as there are none currently. You can find a link to my vid on youtube by http://www.youtube.com/watch?v=crEyOwBe8TI. Mind you i made this video before i fully tuned it. Now the streamers are about 10 inches and the longest spark it made was 12.5 inches. By gettting a bigger secondary more capacitors and more NST power you can increase the spark
Derin in reply to fatboyslimOct 12, 2008. 2:25 AM
TESLA-MARX COMBO FTW!
cowboy4884 in reply to DerinOct 14, 2008. 3:49 PM
Right now I'm currently using a Peter Dahl Plate Transformer, 21,000 volts at 2.6 amps and its arcing about 18 inches. I built a tesla coil years ago when in school but it only arced about 12 inches and the arc wasnt very impressive. I just recently went to a swapmeet and picked up another plate transformer that put out 50,000 volts at 10 amps. The main reason I grabbed it was that the laminates can be disassembled and either the primary core or the secondary core can be removed. The secondary was wound with about 6 gauge wire, the wire is a flat stock type thats 1/8" X 3/8" and I figure that theres about 125' of wire wound on the core and I have about 1000' of 14 gauge wire on hand that I could rewind the secondary with. I could also play with the primary windings and adjust it to boost the secondary voltage. Theres plenty of room to work with. I figure that when I rewind the secondary I'll only be using about half of the usable space.
maxhumphries says: Oct 7, 2008. 2:27 AM
anyone have any idea if you can make this portable, i'm a propsman by trade and a battery version would be very useful...
maccag115 in reply to maxhumphriesMar 7, 2009. 8:04 PM
you can buy a $40 jacobs ladder kit from jaycar in australia, im guessing this would be like radio shack in usa, it uses a vn commodore ignition coil and a 12 volt battery
cybergod in reply to maccag115Jun 12, 2009. 7:44 AM
Hmmm, looks like a trip to Jaycar.... YAY ! Was looking at another place, but Jaycar are local. Hope they have it in stock. Many thanks for the heads-up. My 11 year old son and I will have fun making this one.
maxhumphries in reply to maccag115Mar 8, 2009. 12:03 AM
Thank you Maccag, you've just allowed me to start up a very interesting project. thanks for all the other comments too, very helpful...
title1pro in reply to maxhumphriesFeb 12, 2009. 4:15 PM
are you crazy do you know how much power that takes.
chriskarr in reply to title1proJun 25, 2009. 7:01 AM
I hope he does. Do you realize that your microwave oven, when on, consumes about 1KW? It has a transformer in it that is about 2.2KV at 500 to 1000mA (1A). This transformer is only 12KV at 30mA. 12000*0.03 = 360W. Much less than a microwave oven, so I really have no problem with running this in my house continuously, as long as I was able to have a firm foundation and a method of making sure the arc doesn't heat the rails too much.
I seriously doubt that the author is crazy.
fatboyslim (author) in reply to maxhumphriesOct 13, 2008. 1:42 AM
It is possible to make a battery version if you have a small high voltage unit. Try modifying a stun gun and see if that works. I think there are a couple in instructables on how to build portable high voltage power sources
Sandisk1duo in reply to maxhumphriesOct 12, 2008. 1:07 PM
huevon1b says: Nov 20, 2008. 6:55 PM
I did this once with a couple of bicycle spokes connected to the transformer. They worked perfectly.
Derin says: Jul 14, 2008. 11:13 PM
is that a europe plug?
fatboyslim (author) in reply to DerinJul 15, 2008. 3:52 AM
No. This is a standard New Zealand Plug.
thermoelectric in reply to fatboyslimAug 8, 2008. 6:01 AM
and australia plug
thermoelectric in reply to thermoelectricOct 11, 2008. 6:39 PM
Australia plug!!
Derin in reply to thermoelectricOct 12, 2008. 2:21 AM
dmn
thermoelectric in reply to DerinOct 12, 2008. 2:41 AM
Hehe
Derin in reply to fatboyslimJul 15, 2008. 5:50 AM
oh
alexhalford says: Jul 2, 2008. 3:38 PM
Could I use a OBT? It's rated at 15KV 40mA. Great 'ible. AlexHalford
fatboyslim (author) in reply to alexhalfordJul 3, 2008. 12:37 AM
Yep that would be perfect to use
alexhalford in reply to fatboyslimJul 5, 2008. 10:00 AM
Does drawing an arc from an OBT (such as a jacob's ladder) constitute a short? Thanks AlexHalford
technodude92 in reply to alexhalfordOct 10, 2008. 7:47 PM
Whats an OBT?
fatboyslim (author) in reply to technodude92Oct 11, 2008. 2:45 AM
Its actually OBIT which means Oil Burner Ignition Transformer
fatboyslim (author) in reply to alexhalfordJul 5, 2008. 10:55 PM
well not really. It could be but it will pose no harm to your houses electrical grid.
alexhalford in reply to fatboyslimJul 6, 2008. 2:26 AM
It's not the house I'm worried about. I read somewhere that OBT's can be shorted but only for about a minute, then they need two minutes to cool. Can I draw a constant arc from it or do I have to stop after a minute? Thanks AlexHalford
fatboyslim (author) in reply to alexhalfordJul 6, 2008. 4:02 AM
I haven't heard about a OBIT transformer being only used for one minute. Generally you wont run a Jacobs ladder for more than a minute. But if you want to test it out take the temperature of the OBIT before you turn it on. and then take the temperature in 10-15 second intervals. If the temperature rises dramatically you shouldn't use it for more than 1 minute
sspence in reply to fatboyslimNov 29, 2011. 10:21 AM
I'm using a 14kv 35ma Carlin OBIT, rated for continuous duty. As the steel rods increase in temperature, the arc's don't travel as far up the rods. Thicker rods fixed this issue. The transformer has not increased in temperature significantly, but I've only run it for 5-10 minutes at a time.
fatboyslim (author) in reply to fatboyslimJul 6, 2008. 4:03 AM
Oh and yess you can draw a consistent arc from it. Be careful the wires get HOT
alexhalford in reply to fatboyslimJul 6, 2008. 10:04 AM
OK, thanks for your help. AlexHalford
alexhalford in reply to fatboyslimJul 3, 2008. 10:28 AM
OK, thanks very much.
gumbytig says: Apr 3, 2008. 3:31 PM
I've got an air filter torn apart and it has an ionizer on it. It says it puts out 7kv but there is only a negative lead coming out of it. Any ideas if i could use this for a jacob's ladder? Or something else? Maybe run the other leg of the ladder to ground wire?
fatboyslim (author) in reply to gumbytigApr 4, 2008. 1:15 AM
Where did you measure that it is 7kv. If it says on the ionizer that it is seven kilovolts then ok. If at any chance you cannot find the other +lead then i would reccomend your idea of putting the other wire to ground
gumbytig in reply to fatboyslimApr 9, 2008. 11:34 AM
it says 7kv on the ionizer. It is a little black box with two leads coming in and one out to the spike strip for ionizing.
mannys9130 in reply to gumbytigJul 3, 2008. 7:59 PM
This does not produce ac current only static ions. static electricity. The negative ions charge the incoming air and then a positively charged filter attracts the oppositly charged particles. It is like a magnet, positive attracts negative. you will not be able to make a jacobs ladder with the device you have, but you can use it to make a high voltage van de graff generator, which is just as cool, and plus you touch the sparks, and not get killed! You could also use it to make cool ion lines in a fog. If you grab onto the one lead that comes off of it, and then point your other hand into a fog, the ions will fly off the points of your fingers and make little trancks! it is on youtube. http://youtube.com/watch?v=iLG8gKb-lyk&feature=user
or someone else put a ible on here on how to use one of these to shock trick or treaters. It works on the same principle. opposite charges will attract, and if someone is charged opposite of the generators lead and come into conntact with it, a spark will jump in the ions attempt to reach equilibrium with the two objects. Another high voltage example is lightning. the two clouds are not charged the same and the spark jumps between the two clouds or a differntly charged object on the ground.
hope this helps.
gumbytig in reply to mannys9130Jul 7, 2008. 2:01 PM
Thank you. Van de Graff would be fun. I'll have to look into it.
instructa-fan says: Mar 19, 2008. 8:34 PM
looks like someone slamming a match on the floor
n0ukf says: Mar 12, 2008. 7:47 PM
When I made one, I used an ignition transformer from an old oil furnace
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
