If you like what you see, subscribe to our show on iTunes and for more Backyard FX, check out our site.
Shopping List
1. An old rigid frame backpack. (I got mine at a flee market for $7 dollars.)
2. A fire extinguisher. (Only needed if you want the blast off smoke)
3. A green screen. (check out the Quick Tip at the end of Episode #1)
4. Spray Paint (Whatever colors you want! I used flat black, chrome and primer gray)
5. Some epoxy.
6. Nuts and bolt. (Check the junk drawer in the kitchen.)
7. F.A.A. flight permission.
8. 45 degree PVC joint (1/2" diameter) (Only needed if you want the blast off smoke)
9. 1.90 degree PVC joint (1/4" diameter) (Only needed if you want the blast off smoke)
10. 1/2" rubber grommet. (Only needed if you want the blast off smoke)
11. A bunch of plastic junk! (This is where the real creativity comes in. Go to a Junk store or garage sale and just look for stuff that might look good as jet pack parts.)
Here's what I used:
- 2 cardboard tubes
- A plastic paper tray (that sits on a desk)
- A plastic paper tray (that mounts to the wall)
- An old cartridge from a slide projector. 2 plastic file dividers. (kind of look like bookends)
- 2 plastic hide-a-key compartments with hinged tops. (I mounted the other junk to this so I could lift up the shell and have access to the fire extinguisher.)
- Some wire mesh I got at an art store.
- A "danger flammable liquid" sticker I got from my friend who works at my local hardware store. (Thanks Elizabeth!)
Remove these ads by
Signing UpStep 1Cut the Frame
try e how they might have your answer if you realy want to put your life and dreams on the line.
That's what I thoought!
