Oh and by the way, this is my first instructable so any comments would be welcome.
Remove these ads by
Signing UpStep 1Tools and Parts.
Tools -
soldering iron
soldering iron holder
solder
electricians tape
solder sucky thing (don't know what its called)
third hand
multi-meter (although i don't actually think i used it but thought i might so took a photo of it)
Parts -
Paddle lever switch or something similar
clock movement
c.d. or d.v.d
battery
battery holder
breadboard
breadboard connecters
motor or LED
By the way, before the advent of digital watches with alarms, what you describe is the way many bombmakers set off their explosive devices. An even less sophisticated procedure used during World War II in a failed attempt to assassinate Adolph Hitler was to break the neck on a vial of acid so that it dripped onto a steel wire. The time delay was in the time needed for the acid to eat through the wire. When that happened, a spring held in tension by the wire released a detonating mechanism. I read about it in Shirer's The Rise and Fall of the Third Reich. When this bomb failed, those who had placed it had to retrieve it unnoticed, lest their plot be discovered. They did.
http://www.xnotestopwatch.com/help/countdown_options.htm
http://www.xnotestopwatch.com/ Free for such little experiments.
Perhaps serial COM port's voltages could be used for power supply, not just for signaling. ;)
