How to Make a Minecraft Auto-Filling Pool.
Introduction: How to Make a Minecraft Auto-Filling Pool.
This uses pistons and redstone to make a pool you can cover up. The pool auto levels itself.
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
Step 8:
Repeat this step on both indented sides.g
Step 9:
Step 10:
Step 11:
Repeat this step on both indented sides. Both torches have a block over them.
Step 12:
Step 13:
Step 14:
Both sides should look like this. Repeaters should all be on 1 tick.
Step 15:
Redstone goes all around.
Step 16:
The block with no redstone on it, you must put it there, or crazy stuff will happen. EDIT- the repeater needs to face the other way.
Step 17:
Cover the mechanism with dirt so it matches ground level again. These two must be left uncovered.
Step 18:
The pistons are now holding wool, and are outlined with wool.
Step 19:
Place two layers of stone* around the pool *or whatever you use to make it.
Step 20:
Design the front of your pool. The chiseled block is showing you where to put the lever. --- The chiseled block is placed above the uncovered redstone- the one closest to surface.
Step 21:
Have water flow from the outline of the pool like in the picture. The water should all be source blocks.
Step 22:
Cover the water with slabs.
Step 23:
Place the lever and enjoy the pool. You can also create pools at ground level, you do the same process, but you dig your hole and place your pistons deeper ;)
Step 24:
In ground pool
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    you need to put instructions on how to make it, like how deep the hole, how many pistons did u use, etc.
    press f2 for a screenshot then go to %appdata%, after that find .minecraft look for a folder called screenshot
    Yeah, it's just that I posted the instructable from my ipod, and I didn't want to take the time to email myself the photos. My computer security system doesn't like instructables.
    Nice job! This looks great, I need to make one of these on my server.
