Introduction: How to Make a Origami Paper Tank
This is a Origami Paper Tank and you can make a lot of them and make a war scene. You can also make them for your kids to play with.
Step 1: Getting the Materials
First you are going to need 1 sheet of print paper and a sticky note.
Step 2: The Origami Fold
Take a corner and fold it to the side and make a crease. Unfold it and do the same to the other corner and unfold. Now you should have an "x". Take both sides of the "x" and push them in, then make a crease so it should look like a triangle. Repeat the same to the other side.
Step 3: Making the Wheels
Now turn it so both points are pointing at left and right. Take both flaps and fold them to the other side. Then take the top side of the paper and fold it to the middle. Now take that side to folded and fold it up and unfold the flaps that you folded to the other side. Do the same to the other side.
Step 4: Making the Tank Appear
Pick one side but your only doing this one time. Take the corners and fold them down and leave a gap in the middle. The gap is going to be where the barrel is going to be. Then flip it over and fold the side you've chosen back and fold the other side back on top of the other side.
Step 5: Locking in the Flaps
Unfold the side you just folded and there should be two flaps. Take the two flaps and put them under the other side's flaps. Then flatten it and there should be two flaps not locked in yet. Take one of the flaps and bring them to the side. There should be a little pocket in each side. Now stick the two flaps in that pocket.
Step 6: Making the Wheels Part 2
Now if you look at the sides of the tank you should see the wheels but flat. So flip it upside down and you can see the wheels and take it and put you index finger in a little pocket on the outside of the wheels and thumb behind the wheel. Push the wheel gently with you thumb and do the same to other the other side.
Step 7: Making the Barrel
Now take your sticky note and roll it with the sticky side at the bottom end. You can make it small or big as you want as long it fits in the hole. I hope you enjoy and please comment if you liked it! :)
