3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Make A PCB
This is a method of making Printed Circuit Boards called the Peel and Press Method.
Step 1Printing and Cleaning
Print the board design using a laser printer, on glossy paper. The best type is Staples Photo Basic Gloss. After printing you cut the PCB to the size of the board design. Once you have done that clean PCB with a stainless steel scourer.
25 comments
May 6, 2010. 7:26 PMW6LSN says:
Stainless steel/metal scourer likely too aggressive.  Use plastic scrubby and gently clean it
Apr 25, 2011. 2:02 AMjwoo2023 says:
i agree. :D
Oct 24, 2009. 2:49 AMhiggzy77 says:
Where can you obtain ferric chloride?
Great post...but pictures would make it excellent
Thanks
Jan 11, 2010. 12:28 PMerod998 says:
or also at radioshack'
Oct 31, 2009. 11:15 PMhiggzy77 says:
cheers I'll keep my eye out for it
Sep 25, 2009. 12:48 PMRe-design says:
In step 2, you have it out of order just a bit. You peel the paper then repair any damaged tracks. Nice explanation otherwise.
Jul 15, 2009. 7:49 AMM4industries says:
AAAAhhhHHH! NEEDS......PICTURES.....!
Jul 22, 2009. 1:00 PMM4industries says:
Great! Just dont make the mistake that I did on my first instructable and google 3/4 of the pictures! No one liked it that much!
Jul 6, 2009. 9:05 PMjernax says:
what happened if the printed gollsy paper is hotted with iron?...is the printed pcb lay out will transfer its immage to the pcb board?...is this an ordinary pcb board are you talking about?...
Jun 25, 2009. 11:30 PMdkopya says:
also you can try this method with fax paper.
Jun 25, 2009. 11:28 PMdkopya says:
hi !! drill after ferric chloride it is much simpler
Jun 24, 2009. 5:08 AMjman 31 says:
I believe that this is actually called the "Toner transfer method"? The iron settings may vary with the type of iron you use. Mine actually is set to the Polyester setting which is far from the hottest setting. Acetone works well to remove the toner also.
Jun 24, 2009. 3:44 AMjeff-o says:
A fine high-level overview, but this really needs more detail (and perhaps some pictures you took yourself.) There are lots of tricks and things to know that weren't mentioned here...
Jun 24, 2009. 6:30 AMuguy says:
I agree, this doesn't show how to "make" the PCB!
Jun 24, 2009. 8:02 AMPKM says:
Thirded, you need more detail and your own images- otherwise you are just putting other people's Instructions and pictures from the web together. I've never done this but I know there's more to it than that- you should be printing on the darkest/highest quality setting on your printer, you need to iron with a heavy pressure for much longer than ironing clothes, you need to be careful peeling the paper off because it may pull the toner with it, and so on.
Jun 24, 2009. 8:16 AMjeff-o says:
Exactly - those are just a few of many important bits of info that you need for a successful transfer. For the toner transfer step you're describing, you should also place a piece of plain paper between the iron and the photo paper, since many photo papers contain plastic that will melt onto the iron (likely ruining it).
Jun 24, 2009. 4:20 AMVoid Schism says:
Don't you mean nail polish remover?
Jun 24, 2009. 5:19 AMBiopyro says:
Yes, nail polish remover is mostly acetone.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:PARKOUR123
