How to Make a Paper Origami Candy Box
Published
Introduction: How to Make a Paper Origami Candy Box
The Origami Paper Candy Box can hold candy or chocolate wrappers. It can be useful if you don't have a trash can nearby or to lazy to walk to the trash can.
Step 1: Begenning Part
Get a square piece of paper then fold it in half and unfold. Then turn it around until the crease you made is pointing at left and right and unfold.
Step 2: 2nd Part
Take a corner and fold it to the center of the paper, do that to all of the corners. Once your done folding all the corners to the middle, flip it over and pick one of the corners and fold it in half and fold it in half again.
Step 3: 3rd Part
Unfold it one time and pick up the left flap. There should be a pocket on top of the flap, then open the pocket and fold the bottom corner to the top corner and make a crease. Flip it over and do the same thing.
Step 4: Middle Part
Get the bottom flap and fold it and you should see now is two flaps that you can separate if not then turn it and do the same thing until you see them. Then unfold the flap you just folded and open it and fold it up until you make a rectangle shape, then flip it over and do the same thing. Now when your done take one lair of the paper and fold it to the other side and again do the same thing to the other side.
Step 5: 5th Part
Take one side of the paper and fold it to the middle and repeat it to the other sides, make sure it one lair. Once you done fold one flap from the bottom to the middle and do the same to the other side. Then flip it over so the point is pointing at you.
Step 6: Last Part
Now take both flaps and put it up. You should see the middle kind of opening, but if its not open then don't worry. Put one of you fingers in the opening and press on the sides until it makes a square shape and your all done, enjoy! :)
Please leave a comment if you liked it.
    • Backpack Challenge
      Backpack Challenge
    • Stick It! Contest
      Stick It! Contest
    • BBQ Showdown Challenge
    4 Discussions
