loading
Step 2: Putting the Cords and D-ring on the Snap
Fold your cords in half and run each of them through the end of the snap that has the single slot. Now run the D-ring through the cords and place close to the snap. you will now run the loose ends of the cord through the loops of cord that are sticking out of bottom of the snap. Pull the cords tight so that the loops are tight
U need to be able to do this colar and lease and able to hook tags for a service dog but also completely eithout metal. Its easier in airports without metal. .can anyone help?
<p>Go on e-bay. They have all the parts you need in plastic.</p>
I need**
Dog harness
Great instructions. I have a question though: I wanted to make a 22&quot; collar, I measured out 88&quot; of cord, but my collar only turned out to be 12&quot;. Any suggestions?
Alternatively, you can clamp it to a door, so the cord(s) fall straight (and untwist) when you aren't working with them, so the knots will lay straighter.
since you wait until the last step to burn the ends, tightly winding some scotch tape around the ends should work. i use this of my shoes when the aglets wear off...
I know your post is like 3 years old, but if you don't know this you need to know it... <br> <br>Play with heat shrink tubing... Works awesome for rope ends and aglet replacements!
I would add another metal d ring so that the leash attached to both sides of the snap.
Good idea. A turn buckle or a small caribiner and a steel O ring would do it too.
is that slap hard enough to hold the dog ? i have APBT and he is pulling like bull.
If it's made out of paracord, (one length of paracord can hold 550 lbs. [In weight] ) But then again any knot in any length of cord or rope deduces it's strength by 50%
can you make a paracord dog walkking harness?
whouldint it choke her in the rain
snazzy!
thanks.veeeeeeeeery nice.
Is that a Vizla its so cute, i have one too
I prefer a ''stick'' lighter to melt cords, as I find I am less likely to burn my fingers.&nbsp; I&nbsp;mean the kind you can light a candle with.
I cheat and skip this step...I am barefoot most of the time anyhow, so I&nbsp;run a large loop thru the other side and hook it over my big toe.....Start off sitting 'indian style' and then extend your leg as you need to. This way I can work anywhere I want.&nbsp; This is the method I used as a kid when I used to make lanyards and friendship bracelets..
Love all your instructables, and your blog, almost as much as I love your pictures of Jersey. :)&nbsp; I think the pathos of dog photo faces is inversely related to their degree of spoilage.&nbsp; (Which means Jersey is a testament to what a nice life he has!)&nbsp; Please keep up your great ideas!<br />
About This Instructable
241,955views
575favorites
Bio: I love to make things & work with my hands. I mostly make stuff for dogs and sometimes I dabble with recipes, too. Right now I ... More »
More by Doggie Stylish:Easy No Sew Clown Halloween Dog Costume Make A Banana Split Dog Costume Shark Fin Dog Harness
Add instructable to:
