loading
Step 9: Finishing The Cord Ends Part Two
This is where your hemostat clamp comes in handy. If you don’t have a hemostat, that’s okay. This knotting work isn’t really tight, so a pair of needle nose pliers will work just fine. Find where the turquoise cord passes under a blue cord. Pass the hemostat underneath the blue cord, grasp the turquoise cord with the hemostats and pull through. Repeat this with the blue cord. Do this "back knotting" one more time . Now stretch the collar out with your handsto let the cords `settle` and trim the cords as close as you can to the collar.
Dog harness
Great instructions. I have a question though: I wanted to make a 22" collar, I measured out 88" of cord, but my collar only turned out to be 12". Any suggestions?
Alternatively, you can clamp it to a door, so the cord(s) fall straight (and untwist) when you aren't working with them, so the knots will lay straighter.
since you wait until the last step to burn the ends, tightly winding some scotch tape around the ends should work. i use this of my shoes when the aglets wear off...
I know your post is like 3 years old, but if you don't know this you need to know it... <br> <br>Play with heat shrink tubing... Works awesome for rope ends and aglet replacements!
I would add another metal d ring so that the leash attached to both sides of the snap.
Good idea. A turn buckle or a small caribiner and a steel O ring would do it too.
is that slap hard enough to hold the dog ? i have APBT and he is pulling like bull.
If it's made out of paracord, (one length of paracord can hold 550 lbs. [In weight] ) But then again any knot in any length of cord or rope deduces it's strength by 50%
can you make a paracord dog walkking harness?
whouldint it choke her in the rain
snazzy!
thanks.veeeeeeeeery nice.
Is that a Vizla its so cute, i have one too
I prefer a ''stick'' lighter to melt cords, as I find I am less likely to burn my fingers.&nbsp; I&nbsp;mean the kind you can light a candle with.
I cheat and skip this step...I am barefoot most of the time anyhow, so I&nbsp;run a large loop thru the other side and hook it over my big toe.....Start off sitting 'indian style' and then extend your leg as you need to. This way I can work anywhere I want.&nbsp; This is the method I used as a kid when I used to make lanyards and friendship bracelets..
Love all your instructables, and your blog, almost as much as I love your pictures of Jersey. :)&nbsp; I think the pathos of dog photo faces is inversely related to their degree of spoilage.&nbsp; (Which means Jersey is a testament to what a nice life he has!)&nbsp; Please keep up your great ideas!<br />
About This Instructable
237,748views
574favorites
Bio: I love to make things & work with my hands. I mostly make stuff for dogs and sometimes I dabble with recipes, too. Right now I ... More »
More by Doggie Stylish:Easy No Sew Clown Halloween Dog Costume Make A Banana Split Dog Costume Shark Fin Dog Harness
Add instructable to:
