Introduction: How to Make a Portable Iphone Charger
Have you ever been on the road and had low battery? Well this is your solution!
Step 1:
First find a car charger like the one above.
Parts:Car Charger
9-Volt Battery
9-Volt Battery clip
Electrical tape
Altoids tin
Optional: Soldering Iron
Step 2:
Then proceed to take the device apart. Don't break the internal components though!
Step 3:
Connect the battery clip to the battery. Then grab the bare car charger. Grab the positive wire and the clip and wrap the exposed wire around the tab. Do the same for the negative wire, except wrap it around the spring.Then tape or solder them in place.
Step 4:
Then a little LED should light up on the bottom or if that is not applicable plug in your device to confirm it works!
ENJOY!!
