3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Make A Potato Cannon (Combustion) Advanced Ep 1 of 2
video How To Make A Potato Cannon (Combustion) Advanced Ep 1 of 2
Finally!
Here is a tutorial video on how to make a combustion potato cannon from the man behind www.themonkeybase.com ..
TheBuG or MushiYoshi. The video shows how i made my standard size potato cannon step by step.
Made in Norway
For more info about this cannon and how to make one, go to www.themonkeybase.com and go to the potato cannon link
25 comments
Feb 14, 2012. 4:54 PMAron313 says:
did you soak a rag in gas and shoot it? Howd you do it?
Apr 8, 2009. 6:13 AMKid Flash says:
I too would love to know how you made the explosive...
Oct 18, 2011. 12:03 PMMistaStokes says:
I saw somewhere instructions by the author on how to make it. One would put gasoline in a plastic bag, put said bag into an aluminum can that fits in the cannon, and then attach steel wool to the back of the can. Not really an explosive, more of an incendiary.
BTW don't try the gunpowder thing. I reload shot shells every tuesday so I have played a lot with modern smokeless powder. It doesn't explode, only burns like a match, even if placed in confined containers (PVC, I haven't and won't try metal), and it is VERY expensive.
Dec 16, 2009. 7:49 PMMrMystery96 says:
simply put, an iron rod in aball of paper, with the powder from a .30-06 cartridge in a pouch, attacked to the front. or take a pack of about 100  20gram BB's ina two inch pouch behind a whole lot of caps for a toy gun. then, when fired at a fairly stiff surface, the resulting explosion releases shrapnel to great distances. even better, wrap it in thin wire, then slice the wire at certain intervals, creating even more deadly bomb.
Oct 9, 2010. 7:47 PMmatt09 says:
why do u wanna kill people with this?
Apr 20, 2009. 4:17 PMmaster lurtz says:
It doesnt realy look like an explosive, more like a molotov to me, just judging by the fireball. However if you wanted to make an explosive projectile (not recomended!) then you would use a pice ov pvc pipe and flare one end to make a "rocket" (instructions alsewhere online, like at burntlake) then fit a live bullet or shotgun shell or whatever (might be better if the bullet or the shot was removed but the primer left in place) into the nose of the "rocket" and glue it there. Then fill up the pipe with your desired explosive and block off the end so the explosive doesnt fall out, you may wnt to mix some shot or some shrapnell in with the explosive to make it more effective anti-personell(zombies). Then get a pvc endcap to put over the nose and line up a bolt or nail in a hole drilled in the endcap so that when it hits the target it will initiate the primer and detonate the explosive.... maby i should try this and then make an instructable when i find a sobre moment....
Aug 26, 2010. 9:00 PMpufferfish9108 says:
id use some type of impact reacting chemical that creates a spark on impact and a bag of c4/anfo/black powder/butane/propane/I also like putting hairspray (in the can) on the impact chemical. that KICKS A**!!!!!!!!!!!!!
Nov 29, 2009. 12:49 PMlollerskates says:
It's not really like a molotov. You're correct, molotov's don't explode, but as the flammable liquid splatters upon the destruction of the container, so do the flames. However, the flaming projectile in the video did appear explode. There was an obvious explosive flaming cloud expanding upwards and outwards once the projectile made contact with the hill, which would make it an explosive.
Jun 13, 2009. 6:15 AMjmeister15 says:
Or you can glue 2 pvc endcaps together drill a hole and put a sparker from the pushbutton kind of lighter in the nose so that the sparks are inside and the button is outside Then put propane or somthing inside
Jun 28, 2011. 8:28 PMFragite says:
How much would this gun cost to create? I really want to build one, but I need to get some more money first.
Jun 21, 2011. 10:44 PMdrabinowitz says:
that is amazing! extremely clever design, might I ask what is the fan for?
Oct 9, 2010. 5:24 PMmatt09 says:
you do realize mushi in german means vagina right?
Aug 22, 2010. 6:36 AMturbotonic27 says:
where is the fan used for ?
Jan 29, 2010. 5:17 PMlaughing_man says:
 The shot with the fireball was a video taken from www.themonkeybase.com... In a nutshell, it's made with a can of "fish balls" that fit the barrel nicely, a bag of gasoline tied to the bottom of the can (inside), and a small piece of steel wool secured onto the bottom of that can (held on with a piece of perforated plumbing strap.)
When you launch it, the steel wool ignites until impact, where the bag of gas is broken and ignites from the wool. More detailed directions on their site.
May 1, 2009. 1:36 PMOrro says:
Mean Cannon!!! I am going to build one today!!
Mar 28, 2009. 2:24 PMIX Smith XI says:
How did you make the firebombs?
Dec 29, 2008. 11:58 AMfrankinator says:
using the cola corks for vent is a great idea so if it does by any chance ever fail those will blow out instead of the entire contraption exploding
Feb 16, 2009. 9:18 AMking_zilla says:
what is a cola cork?
Jan 23, 2009. 5:16 PMphotis22 says:
what did you use for the explosive in the big one?
Jan 21, 2009. 8:22 AMTURBOSOPPEN says:
hvor kjøpte du røra og de orange greiene?
Jan 8, 2009. 7:05 PMlukichu says:
that has a crazy recoil for a potato gun
Dec 29, 2008. 7:05 PMblugyblug says:
Finally. An ADVANCED combustion cannon on instructables. All the combustions out there a mini combustions made from little bottles that shoot about 10 metes -.-
Dec 22, 2008. 10:30 AMjema1127 says:
lol
Nov 14, 2008. 6:50 PMInfekchun says:
You go all out dude! nice gun
Oct 13, 2008. 2:35 PMcowscankill says:
Nice gun! You did great!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
25
Author:Spudbuster-TheBuG
