How to Make a Pull Ring Fuse
2,732
28
Posted in HomeLife-skills
Introduction: How to Make a Pull Ring Fuse
About: Feel free to check out my Instagram and youtube, they are both donttrustthepig. A wannabe machinist. I'm always trying to improve my techniques. Most of the time I'm making lantern keychains
Step 1:
You first need a book of paper matches
Step 2:
You also need some masking or painters tape and a small piece of duct(duck) tape. And a paper clip
Step 3:
You new to pull the matches out of the book, but save the striker. Set the striker aside, you'll use that later
Step 4:
You then cut the staple from the matches. Set 2 matches aside with the striker.
Step 5:
You then need to pull the remaining matches into groups of 2s or 3s.
Step 6:
You then need to take the masking tape and take a 3inch strip. I made mine longer and stuck it to the table to make it easier
Step 7:
You then take the sets of matches and line them up with the paper, like in the photo
Step 8:
Once you have that done you need to take a second piece of tape and put it on top of the matches
Step 9:
You then need to cut off the " shaft "of the match just below the match head. You should have something like this
Step 10:
Now you take the striker from before and put a piece of duck tape on the back and trim the excess tape off. You then take a paper clip and make a ring with it.
Step 11:
You then need to take the 2 matches that you set aside before and take them to the side of the fuse. You then need to trim off the tape that covers the colored match head. ( I set my matches too high, that's why it didn't light right away in the video.)
Step 12:
You then put the striker through the loop of the paper clip and put it over the matches. Then put a rubber band around it. The tight ER the rubber band is, the tougher it is to pull, bu I it's too loose it won't light
Step 13:
And it's done!!! Feel free to comment and/or follow me. Thanks( sorry I can only get a link to the video)
http://youtu.be/uck2y0XoFf8
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
