How to Make a Simple Arduino Ultrasonic Distance Sensor
Published
Introduction: How to Make a Simple Arduino Ultrasonic Distance Sensor
About: I am a 14 year old kid that is interested in mechanics and electronics. I build and fix things from earphones to cars.
This will be a simple tutorial on how to make a Arduino Ultrasonic Distance sensor in Centimeters. You will need to know basic electronics, Arduino, and how to use a breadboard.
Step 1: What Is a Ultrasonic Sensor
A ultrasonic sensor is a sensor that sends out high frequency sound waves that bounces off an object and gets reflected back to the sensor to the Arduino. The diagram shows how it works. This is the same way bats can tell how far they are from objects and prey. That is really how it works, pretty simple.
Step 2: What You Need?
You will need
ultrasonic sensor
arduino
wires
usb cable
computer
Step 3: Schemactic
The schematic is pretty straightforward. The VCC and GND wires go to the VCC and GND terminals of the sensor. The trig terminal goes to pin 2. The echo terminal goes to pin 3.
Step 4: The Code
const int trigPin = 2;
const int echoPin = 3;
void setup() { // initialize serial communication: Serial.begin(9600); }
void loop() { // establish variables for duration of the ping, // and the distance result in inches and centimeters: long duration, inches, cm;
// The sensor is triggered by a HIGH pulse of 10 or more microseconds. // Give a short LOW pulse beforehand to ensure a clean HIGH pulse: pinMode(trigPin, OUTPUT); digitalWrite(trigPin, LOW); delayMicroseconds(2); digitalWrite(trigPin, HIGH); delayMicroseconds(10); digitalWrite(trigPin, LOW);
// Read the signal from the sensor: a HIGH pulse whose // duration is the time (in microseconds) from the sending // of the ping to the reception of its echo off of an object. pinMode(echoPin, INPUT); duration = pulseIn(echoPin, HIGH);
// convert the time into a distance inches = microsecondsToInches(duration); cm = microsecondsToCentimeters(duration); Serial.print(inches); Serial.print("in, "); Serial.print(cm); Serial.print("cm"); Serial.println(); delay(100); }
long microsecondsToInches(long microseconds) { // According to Parallax's datasheet for the PING))), there are // 73.746 microseconds per inch (i.e. sound travels at 1130 feet per // second). This gives the distance travelled by the ping, outbound // and return, so we divide by 2 to get the distance of the obstacle. // See: http://www.parallax.com/dl/docs/prod/acc/28015-PI... return microseconds / 74 / 2; }
long microsecondsToCentimeters(long microseconds) { // The speed of sound is 340 m/s or 29 microseconds per centimeter. // The ping travels out and back, so to find the distance of the // object we take half of the distance travelled. return microseconds / 29 / 2; }
Then go to the serial monitor to see the distance
Step 5: Closing
That was the tutorial on how to use the sensor. If you need help post in the comments.BYE!
    • Casting Contest
      Casting Contest
    • Clocks Contest
      Clocks Contest
    • Planter Challenge
      Planter Challenge
    6 Comments
    well I guess maybe you changed the code or the wrong wiring or sensor, what arduino IDE do you have, or look at the website in the code. Hope this Helps cheers :)
    Hi
    wiring is pretty simple. I doubt there would be problem. Sensor is the same one shown above. Arduino IDE is 1.6.7.
    this is my code.
    void setup() {
    Serial.begin(9600);
    void loop() {
    it's done ..thanks ..code was wrong
    Thank you for tutorial!
