How to Make a Starburst Rubber Band Bracelet
36,573
16
11
Published
Introduction: How to Make a Starburst Rubber Band Bracelet
About: Hey everyone! I am an alien who loves rainbow loom, wwe, one direction, alpaca, and MUSTACHES! Check out some of my instructibles. Thanks for checking out my instructibles. ????
Step 1: Getting the Bands
You will need:
Any loom
A hook
70 bands
A c or s clip
Step 2: Placing the Bands
Place one band from the bottom peg to the next top peg.
Step 3:
Place one band from the first peg to the next peg.
Step 4:
Continue this up the whole side of the loom.
Step 5:
On the last peg, turn in.
Step 6:
Go back to the first peg. Turn out to the first peg.
Step 7:
Repeat
Step 8:
Place one band from the middle pin to the next pin. Repeat this step in a clockwise direction.
Step 9:
This is what your loom should look like.
Step 10:
Place a cap band on the last peg.
Step 11:
Place another cap band in the center of the starburst.
Step 12:
Do this to the rest of the starburst.
Step 13:
Loop the bottom band to the center of your burst.
Step 14:
Go into the middle peg and grab the top band. Loop it to the corresponding peg. Keep doing this in a counter clockwise direction.
Step 15:
After you loop the last band. Go to the top peg if your burst. Grab the next color of band on the bottom pull it over and loop it on itself.
Step 16:
Once you finish looping the bursts, loop your boarder bands. Start by looping out.
Step 17:
Once you finish, stick your hook through all the bands at the top of your loom.
Step 18:
Place a single band on the end of your hook. Pull the band through. Now you can pull your bracelet off the loom. You can add adjusters and your done! I hope you enjoyed this! Bye!
    • Stick It! Contest
      Stick It! Contest
    • Pets Challenge
      Pets Challenge
    11 Comments
    ok,when you "loop the bottom band to the center of your starburst" you take the band and pull it onto the next peg up in the burst of color.oh and a cap band is when you take a color and rap it around your finger 2 times. Then you put it on the bottom, top, and the middle of the starburst. hope it helps you!
    I'm stuck on the part that says "band cap" .-.
    What is a cap band? ...
    Okay nvm, I found out what a band cap is. I'm now stuck on the part where you "Loop the bottom band to the center of your burst."
    You grab the band that is under your cap band that is matching the color of your burst and loop it to the center
    Are you supposed to push all of the rubber bands that are in the starburst down?
