3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Make A Tesla Turbine (Greenest Turbine)
Step 10Copper Air Input Instead of Plastic Tubing
  • last photo ←
To make your finished turbine look better with a copper air input instead of a plastic tubing one you will need the following materials.
Materials
-9" of 1/2" copper pipe
-Pipe cutter
-45 degree copper coupling
-90 degree copper coupling
-Air fitting
-Coupling with threads to fit your air fitting
-Torch
-Solder
-Soldering paste
-Mothers mag and aluminum polish and a rag if you want to polish your cooper
-Teflon tape
-Silicon
-1/2" fasteners for copper pipe
Ok to start we will have to cut our old tubing about 2 inches out. And since that tubing fits perfectly into the 1/2" copper pipe will just slide it right over the tube that is already there so we do not have to drill out our pvc and take the whole turbine apart. Now cut your copper pipe into the following lengths: 5", 3", and 1/2". At this point in time put some teflon tape around your air fitting and thread it into the copper coupling with the threads. Now take the 5" copper pipe you previously cut and put some soldering paste onto it and slip it into the other end of the coupling with the air fitting in. Now fire up the torch and solder these two pieces together.
Take the 3" piece of copper pipe and solder the 45 degree coupling onto it. On the other end of the 45 degree coupling solder the piece of copper pipe that is 1/2" long (this is for the plastic tubing to fit into; it will not be a snug fit into just the coupling so we have to do this unless you want to waste a large amount of glue sealing the two together). Then on the other end of that same pipe solder the 90 degree coupling on.
Now take the 5" copper pipe with the air fitting on it and solder that to the 90 degree coupling that is already attached onto the other pipe. The copper pieces are now all together.
(***Skip this step if you do not want to polish your copper pipe) With all of the pieces of copper together take some mothers polish (if you want to) and polish the copper (I prefer a shiny finish because it will draw more people into looking at what you have really done).
Now slide your tubing into the copper pipe and re-silicon anything if it breaks loose and also put a little bit of silicon inside the copper pipe in the 45 degree angle piece so it make a better seal. Now let this dry overnight. Now that you have done this your project will look much better. Also if you see the pictures with the tape on them it is just holing the copper pipe there until I get some fasteners. But if you have already gotten them fasten away.
5 comments
Jul 13, 2010. 12:13 AMDehLeprechaun says:
daaaang!0_0 at first i was all like "sounds fun" :3 now im all like 'sounds kompicated' :/ how much did it cost u 2 m8k dis?
Jun 13, 2011. 2:54 PMHughGRection says:
Apparently spelling is complicated as well.
Dec 6, 2010. 12:41 AMDELETED_kage_no_akiri says:
(removed by author or community request)
Dec 9, 2010. 10:40 PMPilgrimm says:
Domo Arigato!
Dec 10, 2010. 12:26 AMDELETED_kage_no_akiri says:
Dec 13, 2010. 7:27 PMDehLeprechaun says:
Dec 13, 2010. 8:11 PMDELETED_kage_no_akiri says:
Dec 29, 2010. 3:17 PMDehLeprechaun says:
I was just having some fun with the spelling is all, anyway don't you think this argument is kinda silly. I mean we're arguing about typing skills *_*
Dec 29, 2010. 4:23 PMDELETED_kage_no_akiri says:
Dec 29, 2010. 5:05 PMDELETED_kage_no_akiri says:
Jan 3, 2011. 7:04 AMDehLeprechaun says:
thanks im glad you understand and thanks for the apology
Oct 26, 2010. 4:42 PMchakitodog says:
What do you use to power the turbine?
Jan 21, 2010. 10:21 AMmekennedy1313 says:
Why do you wrap the incoming air around the body of the turbine.  I would think a straight in air pipe would be simpler and not have additional friction of the bends.
Jun 14, 2010. 9:49 AMFirestorm_101 says:
Pardon if I sound ignorant, but would be better to have the end of the tubing a conical shape? To increase initial pressure blowing into the turbine?
Dec 26, 2009. 4:12 PMbodo says:
ok well goood but please how can we calculate rpm and power as wats or hp so we can build biger ones for cars or more i heard that a small replication get 300 hp so it is posible to build in in something to get energy or motion how can we calculate I can not fined it in wiki
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
50
Author:CrazyMachinist94
