Step 9Taking it Further
Another thing to help your project stay together but is not necessary is to use lock nuts instead of regular nuts. I did switch over and use these after I thought about it for a while and I believe it will help to keep your project together longer.
Also one thing that I did not do and I am now wishing I did is polish the ends of my plexi-glass. This is something that I do not know how to do but I imagine that you should be able to easily find it somewhere on the internet.
Something else you may consider is making a steam boiler. This is something that I know how to do but it will take another instructable so if I get enough responses for me to make this I will so if you would like to see one on Instructables please let me know.
You may also want to make a Tesla pump which is just about the exact same thing as this except the water or fluid will enter from the exhaust ports and will exit from where we are putting the air inlet which is where the plastic tube is. Once again I am sorry but I do not know how to make one of these but If you do let me know of the site and I will post a link on how to do this, same for polishing the ends of the plexi-glass. And your turbine could power this too.
These are just add-ons so do not feel that you have to do these things to make your turbine run because I have only painted mine and made a boiler for it which make this project very green. Speaking of that you could also add on a small D.C. generator of some sort and light some L.E.D.'s with it and having your project run something else always makes it look better, please if any of you make one of these send me a picture and I will dedicate a section to all of you that make one.
***Note: you may want to make a ball valve system so you can quickly shut it off if something were to go wrong and it makes it nice to be able to control the speed if you want to I have a picture of this if you want to see mine.
unitednuclear.com/index.php
Of course, he was rather an idiot about his containment procedures and so irradiated his entire block...
http://www.dangerouslaboratories.org/radscout.html
This involves having a parting style tool that is shaped more like a boring tool and using it longitudinally rather than in a cross slide direction. This way you can cut most of the inside waste section as a slug of material to use later. You end up with the ring of material you want to use for your motor casing.
Think carefully about your tool angle clearances so that it is right for both the inner part and outer part of you job. If you can picture it let me know and I will send you a drawing of what I mean. Any good book on turning will show you this technique.
If you think about how a hole saw works and then translate that to a single point tool you will be on the right path. You need to get the absolute best out of all of your materials. I keep buckets of offcut for making other things and it has meant at times I can put off buying new materials. My son and I even used some aluminium scrap when we needed to cast a part for a project. We used a Mapp Gas torch that quickly melted all the materials see http://www.justtools.com.au/prod1874.htm. These torches are cheap and you can do almost everything with them. Let me know if I can help with any machining advice ............... ive only been doing it for 36 years :-)
I will be really interested in seeing your steam projects too...... send me a message when they are up...... Thanks Mal
