How to Make a Triple-single Bracelet and a Single Bracelet on a Loom
23,955
10
Posted
Introduction: How to Make a Triple-single Bracelet and a Single Bracelet on a Loom
Okay first I will show you how to make a triple single then I will show you how to make a single and connect it to the triple to make a bracelet
Step 1: Get Your Stuff Together
You will need
1. Some rubber bands(I used red and green
2. The loom
3. A crochet hook(to connect the bands)
4. Two C clips to hold the band together
Step 2: Start Putting Your Rubber Bands On
You will want to put them on the outside first . One side of the rubber band will be overlapping another and it will be under another. Also the arrow should be facing away from you.
Step 3: Add Triangles Around the Bands
Don't put the triangles on the first clip or the last three. You just make a triangle with the bands
Step 4: Tie the Bands Together
Ol turn your loom the the Cs are facing you. pit a rubber band on the end this is like your beggining triangleFor the first bands of the rows.you put your crochet hook between the triangle band and the band on that hook. You pull the band up leaving one band on bottom from the previous one and you take it and connect it to the next hook. You have to start at the middle since that's what you put on last and is on top then go to the next one on top at the beggining
Step 5: Out One of the C Clips on Each End
Pull just the end rubber bands out a little and stretch them then slip the c clip on you want to make sure you get all of the bands on the ends
Step 6: Now Pull It Off
Pull the band off and you have your triple single part. Now just the single left to make and attach
Step 7: Put on the Bands
Just like in the triple you put one on top of the other except you do this one in a diagonal pattern.
Step 8: Connect the Bands
Take the crochet hook and put it between the top band and the bottom band then catch the bottom on your hook and pull it up and onto the next hook keep doing this tell you're done
Step 9: Connect the Triple Single and Single
Connect the c clip to one end and the other c clip to the other end and pull off the single
Step 10: Now You Have Your Bracelet
    • Trash to Treasure
      Trash to Treasure
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
