If you are bored and would like to change the appearance of your flash drive, let me show you how I improved the look of mine!
This instructable was inspired by: http://www.evilmadscientist.com/2008/how-to-make-a-sawed-off-usb-key/ .
Remove these ads by
Signing UpStep 1: Tools And Materials
A small flash drive / a small SD card and a small SD Card Reader you can find it here
(in my case i didn't find a small flash drive that could fit in my usb cable so i used a small SD card and a small SD card reader)
Tools:
Pliers
Cutter
Tape
Visit Our Store »
Go Pro Today »
"Now we will cut the wire to make it shorter, then strip the wires as shown and bend it. That is all there is to it! See how easy that was? Thanks for viewing my Instructable and have a nice day! "
One at a time.
"Now we will cut the wire to make it shorter." Wire singular, and why do we need to make it shorter?
"...then strip the wires as shown and bend it." Wires plural, but "bend it" singular. Exactly what are you referring to? What do we cut and what do we bend? If we cut wires we must connect them subsequently, or there will be no electrical connection. Your diagram leaves us with bare wires which are unconnected.
Clearly I must have missed something. Rather than me try to work out what, can you examine your instructions, and try to figure our where you went wrong? See, I can only read what is written, you do the describing. Your job.
"that's all there is....." Clearly not.
Being nice.
Good fun, must produce a few puzzled frowns. Don't let the negatives put you off, including my sloppy first.
The entire point of this Instructable....
As for the bit about wire alternating between singular and plural, this seems to be because Mahmoud was sometimes using "wire" when he meant "cable". (A wire is a single conductor, a cable may contain one or more wires.) It's a pretty common colloquialism to say "wire" when one means "cable", though I agree that seeing "wire" and "wires" used together in the same like that is a bit weird.
I think my application will include either an abrasion "caused" separation point or the result of a heat overload "melting" of the cable with visible short of underlying wiring.
I am leaning toward the Shock and Awe factor whether than the mere WTF factor on this one...
Tell them you have devised a way to make the information jump from the ends of the wires.
LOL
sorry hurten
so it depends on how thick you use it
the tape getting hot will become really anoying ... use better those hot retractable tubes !
then why not puting some steampunk object at the end :) lique a pendulum or don't know... a parabol ;P (it is for hacking wifi , hu...)
