loading
You open your bag in silence and pull out your laptop and grab a USB cable and people look to you surprised  and say " What does he think hi€™s going to do with that USB cable?!!" You plug it in your laptop and continue on with your work.
If you are bored and would like to change the appearance of your flash drive, let me show you how I improved the look of mine!
This instructable was inspired by: http://www.evilmadscientist.com/2008/how-to-make-a-sawed-off-usb-key/ .
Step 1: Tools and Materials
Materials:
Old USB cable
A small flash drive / a small SD card and a small SD Card Reader you can find it here
(in my case i didn't find a small flash drive that could fit in my usb cable so i used a small SD card and a small SD card reader)
Tools:
Pliers
Cutter
Tape
Step 2: Open the Cable
We will make a cut in the middle between the two edges of the cable as shown.
Then we will be able to remove the old USB Jack and insert the new flash drive or new card reader.
Step 3: Remove the Old USB and Insert the Flash Drive
Remove The Old USB and  the Flash Drive.
Try to remove the old USB with pliers; then cut the wires and replace it with the new flash drive or the new card reader.
Push it in there as shown.
Step 4: Secure the Flash Drive or the Card Reader in Place
Secure the flash drive or the card reader in place with tape; then cut the tape as shown.
Step 5: Finishing Touches
Now we will cut the wire to make it shorter, then strip the wires as shown and bend it.
That is all there is to it! See how easy that was? Thanks for viewing my Instructable and have a nice day!
Step 6: Done!!
Now you have it , enjoy it. Please comment, follow, rate, and vote for the contest , have a good day.
<p>Cool!</p>
<p>Question: Where does the wires from the USB cord go on the SD card. My friend is making this homemade.</p>
<p>Why doun't you just hot glue it closed so there would be a smaller seem and less sticky electrical tape</p>
This is truly excellent! I've had several flash drives taken, but I bet this one will fly under the thieves' radar- nice one, Mahmoud.
<p>I specifically read this for that. I &quot;lost&quot; one 3 days ago.</p>
thx man and please upload the picture of it and post it in a comment
awsome work
<p>thank you :D</p>
<p>Oooh, I just thought of something, take this but instead of tape use super glue (carefully), so it looks more realistic. Or carfully use epoxy on the inside of the cut edges and glue it that way, or heat up the cut edges slightly and hold them together and then when cooled sand off excess plastic (if there is anyway). Just my thoughts, cool project though. (thumbs up)</p>
<p>thank you :D i will try next time :D</p>
Nice, that is a great idea
awsome work
Hey congratulations on being a finalist in the hack it contest! Good luck to you!
thanks, i appreciate that
You have to solder some electronic parts at the end of the cable! That looks cool!
i will try later
this is mine... i used my old 8 GB Toshiba Flash Drive...n xcept using black tape i used FeviQuick...
wow look cool man , thank you for posting this picture <br>
thank you for this amazing idea
you are welcome :D
Whoah there. At the end there is a picture of a USB drive cable and you say, <br> <br>&quot;Now we will cut the wire to make it shorter, then strip the wires as shown and bend it. That is all there is to it! See how easy that was? Thanks for viewing my Instructable and have a nice day! &quot; <br> <br>One at a time. <br> <br>&quot;Now we will cut the wire to make it shorter.&quot; Wire singular, and why do we need to make it shorter? <br> <br>&quot;...then strip the wires as shown and bend it.&quot; Wires plural, but &quot;bend it&quot; singular. Exactly what are you referring to? What do we cut and what do we bend? If we cut wires we must connect them subsequently, or there will be no electrical connection. Your diagram leaves us with bare wires which are unconnected. <br> <br>Clearly I must have missed something. Rather than me try to work out what, can you examine your instructions, and try to figure our where you went wrong? See, I can only read what is written, you do the describing. Your job. <br> <br>&quot;that's all there is.....&quot; Clearly not. <br> <br>Being nice. <br> <br>
Mahmoud, I apologise, I did indeed miss the point. I assumed we were making something practical - though not sure what, as distinct from making something practical with a practical joke attached. Now makes sense. I also did not take any notice of your name and location, and was unaware that English was not your first language - this has made me aware that I must take greater note of the poster, rather than just studying the post. All mistakes my own, and despite the first post from frozenice, I'm glad you posted here as I would never have found the original. AND you clearly stated that it was not your original idea, and gave credit to the original. <br>Good fun, must produce a few puzzled frowns. Don't let the negatives put you off, including my sloppy first.
Clearly, FirstSpear, you HAVE missed something! <br>The entire point of this Instructable....
I think you missed the point behind this Instructable. The idea is to have a USB drive that looks like the end of a USB cable that has been torn off. That is, it's supposed to look like something that's broken, yet it still functions. The wires aren't supposed to connect to anything -- they're the part that looks broken. They're really just decorative. <br> <br>As for the bit about wire alternating between singular and plural, this seems to be because Mahmoud was sometimes using &quot;wire&quot; when he meant &quot;cable&quot;. (A wire is a single conductor, a cable may contain one or more wires.) It's a pretty common colloquialism to say &quot;wire&quot; when one means &quot;cable&quot;, though I agree that seeing &quot;wire&quot; and &quot;wires&quot; used together in the same like that is a bit weird.
ok you don't get it , the last step is like decorate your own flash drive if you want make this step make it if you don't it doesn't matter ,there is not a connection between the wires .
Great job on this! What brand is the &quot;small SD card reader&quot; that you have? I've briefly looked for something like this but can't seem to find much out there.
thanks and here it is on ebay <a href="http://www.ebay.com/itm/US-Seller-Micro-SD-USB-Card-Reader-Small-Up-to-16GB-MICRO-SDHC-Card-/250955429499?pt=US_Memory_Card_Readers_Adapters&hash=item3a6e1bf67b" rel="nofollow">here</a>&nbsp;&lt;this is what i used&nbsp;
Love it. Consider a light brushing of epoxy or heat melt of surfaces previously cut to re-secure the covering around the &quot;new&quot; USB component. <br> <br>I think my application will include either an abrasion &quot;caused&quot; separation point or the result of a heat overload &quot;melting&quot; of the cable with visible short of underlying wiring. <br> <br>I am leaning toward the Shock and Awe factor whether than the mere WTF factor on this one...
A interesting twist would be to put a little clip on light (low volt single led) on the end of this wire and solder it to the usb card with wires from the other end. That way you can tell people it's a plug in light and they won't suspect the hidden USB Drive.
wonderful idea
This would be great to use in a &quot;wireless technology&quot; class. <br> <br>Tell them you have devised a way to make the information jump from the ends of the wires. <br> <br>LOL
LOL
I might forget it's a flashdrive and accidentally throw it out. Would make for some cool spy gear though.
This is cool :-) you definitely have my Vote!5*
Wow! thanks man
excellent work mate, I love it I think that it would freak a lot of people out seeing wires hanging out of a USB cable.
thanks
You could use a piece of large diameter black heatshrink tubing instead of electrical tape.
that wouldn't quite work the heat shrink wouldn't shape as well as the electrical tape it has too much plastic behind it as the electrical tape has easily moldable plastic and can be done in one to two layers <br>sorry hurten
sorry next thought it depends on if its like a 1 mm or 10 mm heat shrink <br>so it depends on how thick you use it <br>
yes you are right whitejaxon that's whtat i want to say
Nice job. Will make my friends crazy...lol. Thank you for sharing, Mahmoud.
you are welcome
I have done something very similar to this hack. One real difference was that I used heat shrink tubing over the original cable shroud. The beauty of the heat shrink is that it will shrink down and show the detail of the underlying design. <br>
two things i think: <br>the tape getting hot will become really anoying ... use better those hot retractable tubes ! <br>then why not puting some steampunk object at the end :) lique a pendulum or don't know... a parabol ;P (it is for hacking wifi , hu...)
better use heat shrink tube (the large one that fits the usb connector) instead of electrical tape, electrical tape become sticky and peel of easily
oh yeah , but it is hard to get in my country
Greate Job!!! http://www.katanecomputers.com
thanks
About This Instructable
149,708views
245favorites
License:
Bio: thank you sunshiine for supporting me : ) i am mahmoud , i live in Egypt , i like to inventing new things form junk and old toys and More »
More by Mahmoud Alaa:TV kill switch , Arduino Tv-B-Gone!! DIY Bluetooth Controlled Robot (Rover) With Live Stream Video!! My Home Made Dremel or Rotary Tool
Add instructable to:
