How to Make a Wooden Cup With a Lid
Introduction: How to Make a Wooden Cup With a Lid
For this you will need six 11" long 1x6s and a wood lathe
Remember to vote for this in the contests if you liked it and look at my other contest entries and vote for them too if you enjoyed them
Step 1: A Bit Sticky
Start by gluing the six boards together like in the picture above when you are done cut a bit off of each side to ensure they are even
Step 2: Getting It Set
When the glue is dry draw an x from corner to corner and screw in the centred on the x jig to screw to the chuck of the lathe
Step 3: Starting It Off
Put it on the lathe and start carving in your design, it can be just a simple straight up and down cup or an intercut design
Step 4: Carving It Out
When you have got the outside the way you want it you can start carving out the inside like the picture above
Step 5: When You're Done
When you have crafted a masterpiece you are ready to cut it off. You can sand it on the lathe on the slowest speed and then you can cut it off. You can do it by hand or a band saw but the most precise way to do it is on the lathe with the tool I was using in the picture if you do it on the lathe only cut it till there is 0.5" in diameter there then finish it off with a hand saw and sand the bottom of it
Step 6: Style It the Way You Want
When it is cut off you can varnish it, paint it or just put some polycarbonate on it
Step 7: To the Top of Things
To make the lid use the left over wood you should only need like 1.5" but you should have plenty extra
Step 8: Starting the Lid
Start by carving the top of the lid near the chuck of the lathe, the design I am using is just a standard flat lid
Step 9: Making It Fit
Once you have got the design of the lid done the way you want you can move down to the edge a bit and start making a straight line (do not design it) this will be the part that goes into the cup so it has to be a sudden edge so it doesn't fall through as in the picture above make sure to make it small enough to go in smoothly without pressure, but not too small so that it doesn't rattle.
Step 10: Smoothing It
After you have engraved it to the point that it fits you can turn the lathe to the slowest speed and start sanding it use very fine grit to get it extremely smooth.
Step 11: Cutting It Off
When it is smooth as you want it begin to cut it off just like you did with the cup (remember to only go until there is 0.5" in diameter left then cut it off with a saw.) When you have cut it off you will need to sand that part
Step 12: Varnishing
When it is cut off and smooth you can varnish it or just put a layer of polycarbonate on it.
Step 13: Your Done!
Put the lid on your cup with all the things you want to fill it with and enjoy!
Step 14: Vote Comment and Follow
Remember to vote for this in the wood working contest if you liked it also tell me what you guys want me to do next in the comments hope you guys liked my instructable!
Thanks for following!
By the way I will be doing a giveaway of a three month pro membership! You can win simply just by following me. On May 1st I will put all my followers names in a hat and draw a name. I will then send a private message to the person and they have to reply within 3 days so they can claim their prize! If they do I will tell them the code, but if they don't I will give it to someone else.
Until next time...
    • Trash to Treasure
      Trash to Treasure
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
    Thanks for the tip! Remember to vote!
    Rather than having the tool rest parallel to the axis turn it so it is parallel to the cutline. That way you can get it closer to the work.
    Thanks you for all the votes and tips I really appreciate them! If you have not voted yet remember to if you liked it
    If you arrange the blank so the grain of the wood is the top and bottom you don't have to try to hollow out the end grain.
    Another trick is to use the largest Forstner bit you have to initially hollow the cup. This also sets the correct depth and all you need then is a bowl gouge to finish the job.
    When sanding on the lathe set the lathe for the slowest speed not the fastest. The faster the lathe turns the more you flatten the grain and the more trouble you will have applying stain.
    Thanks for telling ! I was not aware of that…
    I VOTE !!!…
    With pleasure…
    I prefer to sand and finish the wood on the lathe- makes the operation better and fasster.
    I'm sending this one on!
