Introduction: How to Make an Airsoft Base in a Wooded Area
In this instructable i will show you how to make an airsoft base using only natural materials
Step 1: Gathering Materials
First look around usually there are fallen trees or logs/ sticks. If not I can't help you. "It goes faster if you have logs/ fallen trees because they are generally thicker."
you will need:
-logs, fallen trees, or sticks
-saw hand or chain
-your self or someone to do the work for you
-rocks
Step 2: Preparing the Materials
Cut the logs into uniform lengths about 4-6 feet depending on how large you want the fort to be. I would cut a thin stick to the size you want the logs to be.
Step 3: Stacking the Logs
Pretty much you are making extremely large lincon logs. You should stack the logs similarly. Add nails to increase stability especially if your location is on a hill.
Instructables Outdoor Projects Contest
