How To Make An Origami Cup
Step 3The Holder
The Holder
This is how you build the holder. I hope you saved that little strip!
Photo 1: This is the strip.
Photo 2: Wrap the strip around the cup.
Photo 3: Now tighten as needed, you want a tight fit.
Photo 4: Put on the tape.
Photo 5: Finished holder. Try to keep it and reuse it.
2 comments
Dec 17, 2010. 4:06 PMHALOPLAYER101 says:
Hey Iknow a better way!Do the same step`s but when yourn done,cut a little strip that fit`s under it. Put tape on it you`ll be sure for so it dose`nt leak!(I Used Construction Paper)
Aug 26, 2009. 7:05 PMspiralofhope says:
You don't need a piece of tape for the last step. Here's how I did it: - Take your long strip of paper and place it down so it's landscape in front of you. - take the bottom edge and fold it roughly into the middle - take the top edge and fold it so that it's roughly near the bottom - Take the left edge, and fold one corner up, so you made a triangle out of that edge - Pick the page up, and curl the edges together - feed the triangled edge into the opening on the other side You could also pinch a fold or two in your ring, to help it not unfurl so much. It's not as good as tape for resisting weight and water, but it works.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:Mintyhippo
I like k'nex stuff, legos, programming, airsoft guns, computers, knives, camping, guitar, piano, swimming, video games(DUH), cats, food, real guns, fps, music (classical to metal), fire and making thi...
more »
