How to Make Bear Mouth Pop-up
Introduction: How to Make Bear Mouth Pop-up
This is Bear Mouth Pop-up.It's very easy makes pop-up.So,i have learned minutes to minutes for pop-up makes.Not so much hard making with pop-up paper.paper pop-up means that if you opens greetings card then bear mouth will open look likes 3D.It's fun makes pop-up makings.
Pop-Up Making requires materials :-
1)Paper Size about A4 or Origami papers.
3)A pencil,markers or pen if you need.
4)Decorating Supplies!
Step 1: Startings Paper Pop-Up
Begin With A4 Size paper,Construction paper or card stock.Card stocks works best and easily obtained from any office supply Store.You may also begin by using a manila filing folder.This may be easier for very young pop-up makers.
Now,Then Fold the construction paper in half to form a card.
Step 2: Step 1
Draw a jagged line instead of a straight one and you have a mouth with teeth.
After,cut the jagged line Starting at the folded edge.see picture how look like cut the jagged line.
Step 3: Step 2
Fold back the top flap to form a triangle & Crease with your thumb or finger.
after fold back to the bottom flap to form a triangle & crease with your thumb or finger.then,put the bottom triangle flap back in its original position.
Put the top triangle flap back in its original position again.
Open the card up like a tent.
Step 4: Step 3
Okay,then using your thumb or fingers,push the top triangle through to the inside and using your thumb or fingers,push the bottom triangle through to the inside also.
Close the card and press firmly.
Step 5: Done Step
open your Bear mouth pop-up and decorate your bear mouth pop-up.use pencils,markers,crayons.
(avoid paint since it.)
Thanking you All!
Please Follow,Vote & Comments.
2 People Made This Project!
  • Paper Contest 2018
    Paper Contest 2018
  • Trash to Treasure
    Trash to Treasure
  • Pocket-Sized Contest
Simple and cute. I love it!
me and the bear got into it bc the scissors bit me and he thought i was blaming him
Cute! Now let me put my finger in and... AARRRRRR IT BIT ME!
very cute! love it! only thing, if your paper is not very thick, markers will show through. also can use thick tip markers.that will looking good.. And thank you very much for committing me.
I used to use this same method except using a straight cut instead of jagged teeth. I would then draw a frog and write "hoppy birthday" on the front to use as a birthday card!
Forgot to say, if you fold the piece of paper in half first and do this to one half only, then you get a solid 'front cover' which means that you can use it as a card. It also means the the mouth has a back to it, so you can colour in or draw on a tongue etc!
