Introduction: How to Make Buildings Pop-up Card
Hello,
I have Nice makes Buildings With pop-up Cards.It's very easy makes.You can also Send gift,give to Citizen Personal.See down what you need materials..
Need required Materials-
1)Paper(Card Stock,Origami,etc)Only Big Size Paper Like A-4,Card-sheet Paper.
2)Scissor
3)Blade
4)Pen,Pencil & Marker.
Step 1: Step 1
Begin With Construction Paper or card stock.(Card stock is works best making and easily obtained.)you may also begin a manila filing folder.This may be easier for very young pop-up makers.
Now next,fold the construction paper in half to from a card.&return to the position for folded.
see picture look like folded line on the paper.
Step 2: Step 2
Draw an One parallel small,second try a bit big draw parallel and third parallel draw big lines.& last draw medium parallel lines.please draw perfect fold and Cut lines possible if you can Fold.
Step 3: Step 3
Now you can cut the lines before see picture.and now try fold the lines.see the images how to fold.and crease well along the edge with your thumb or finger.
Step 4: Step 4
If you folded all the lines (Fold Lines)then Close the card If you can.Now Press firmly.And Open The Buildings Pop-Up Cards.
Draw Your title like "Happy Citizen" & Decorate what you need.
Please Vote,Follow & Comment.
3 Comments
Do you have to use construction paper or card? do you think I could just use two layers of normal paper glued together?
Yes I have used anytime.If you using normal Paper glued that will problem stick and not probably Stand up.Why you need use glued?
I thought I could use two pieces of paper glued together because it would (hopefully) add some extra stability. But I might just get some construction paper from the shop tomorrow :P
