Like a lot of people, the first time I made butter, it was an accident. I was whipping some cream and got distracted. I got back just in time to see the whipped cream separate into butter and buttermilk. (Hmmmm... I don't think that ever happened with the powered whip cream mix Mom bought.- I love you Mom, but you know - you and cooking = Pellegrino and Crisco.)
I was bummed that I screwed up the whip cream, but It was still really cool how it became butter in just seconds. So I started making butter at home and I'd thought I'd show you how I do it.
I always find that these kinds of things are a lot easier, and less intimidating, if you can watch someone do it. So watch the video and you can see me make butter, start to finish, in real time, with no editing. It's not as messy as it looks in the video - unless you are making a video of yourself doing it.
In the video I use 2 cups (a little less than .5 L) of cream so it takes twice as long. You will see the cream break down at about 3 minutes. Because I didn't use the splash guard, I also couldn't run the mixer at full speed.
With washing, it only takes a little over 9 minutes to go from 100% Heavy Cream to finished homemade butter. That's probably faster than it would take Usain Bolt to run to the corner store, buy a pound of butter (with free Mono and Diglycerides, Polysorbate 80 and Carrageenan) and run back home.
These are the ingredients.
Manufacturing Cream (or Heavy Cream)
Sea Salt (optional)
These are the tools I used:
Kitchen Aid Stand Mixer
Wire whisk attachment
Beater attachment
Splash guard - Omitted in video - you'll see why it's important
(ew, i think there is butter in my hair, yummm, yep it's butter.)
Ice water
Spatula
Parchment paper or Plastic wrap
Remove these ads by
Signing UpStep 1How to do it
When I went to buy cream at Smart and Final (restaurant supply that is open to the public) I saw "Manufacturing Cream". I didn't know what it was, but it was a little higher in fat than Heavy Cream. It was only pasteurized, not ultra-pasteurized, and the only ingredient in it was "Heavy Cream".
I bought a 2 quart (1.89 L) carton for $7.
I researched it and found out "Manufacturing Cream" is the cream restaurants and bakeries use for baking and cooking (the names of types of milk/cream are different all over - even from state to state. I'm in California.) It does not have all the additives like Ultra-Pasteurized Cream. The flavor is very good. It doesn't last as long as regular ultra-pasteurized heavy cream though.
In the video I'm using 2 cups of cream. I went ahead and weighed the cream, and then the finished butter, so you could see how much butter I got out of it.
Before: 2 Cups (a little less than .5 L) Cream = 1 lbs = 16 ounces = 450g
After: Butter: 7 ounces = 198g
Total cost was $1.75 (sorry, don't know how many €'s, or £'s, or Can$'s or Aus$'s, or ¥'s, etc. that is)
Almost half of the cream was butter.
You want the cream to be between 61°F (16°C) and 65°F (18°C) to get it to separate fast.
I usually do 1 cup (about .25 L) of cream at a time, and it takes about 90 seconds to separate.
I put the cream in the mixer with the wire whisk. If you have a splash guard - USE IT. I left it off in the video so you could see what was happening. The camera, my kitchen, and I, all got splattered with buttery goodness.
It will whip into whip cream, and right after it gets to firm peaks, it will start to separate. SLOW the mixer down, or it will make a mess and splash all over the place - even with the splash guard. Just let it run another 5-10 seconds.
Then switch to the beater blade. If you stay with the whisk, the butter clumps up inside the whisk and is very hard to get out.
Beat the butter on a slow speed for about 10 seconds to let it finish separating. Using a spatula, squish the butter into a lump in the bowl, then pour the buttermilk off. You can use this buttermilk for baking. Some people like to drink it.
Now wash the butter to get all the buttermilk out. If you leave buttermilk in your butter it won't last nearly as long. If you are the kind of folks who like to leave butter out at room temperature, you might find that it has gone rancid if you leave any buttermilk in it.
Add some ice water to the bowl and beat it on low for around 10 seconds.
Use your spatula to squish the butter into a lump again then pour the water off.
Keep repeating the rinse process until you get clear water.
I do the last wash by hand. Pour in some ice water and squish the butter around to see if you can get any more milk.
Pour that water out. Squish the butter around some more to squeeze out any water that is in the butter. We don't want to leave any water suspended in the butter. Keep squishing it and pouring off any water you get until you don't get any more water - about 3 times for me.
That's it. You have butter.
If you like whipped butter, you can just put it back on the mixer and beat it on high, for a minute or two. If I want salted butter, I put some sea salt in while it is whipping. About a 1/4-1/3 tsp per cup of cream.
Whipped butter spreads easier and melts faster. If you use whipped butter for baking - you cannot measure it by volume. You can only measure it by weight. Because we whipped air into it - 1/4 cup of regular butter will be about 1/3rd cup of whipped butter (depending on how much air you whip into it). You smart Europeans, who bake by weight already, need not worry.
(The video is available in High Quality - It's easier to see the splattering of butter all over me and my kitchen)
Also, what is a good salt to pint ratio? And has anyone tried making flavored butter during the process? I am thinking cinnamon or orange or something that uses spices or extracts.
After boiling and cooling, formed a thick cream that my mother removed and froze.
Once gathered about a quart of cream, I was asked to make butter. I used a bowl and a wooden spoon to beat the cream. After beating the cream for about 30 minutes it was forming lumps. A little more time for the butter to form.
After this I put a bit of cold water to wash it, taking care not to wash several times to avoid losing flavor.
Note:
The cream was thicker than what is presented in the film and the lumps formed soon.
In the washing step, you should mix the butter slowly to prevent water from aggregating it.
Thanks for sharing the info. That helps everyone.
I used the only mixing tool available in my house: a hand mixer and a tall cup. that made a fine mess but the result is so delicious.... never mind it took way longer to clean up than to make!!
Next time I HAVE to dig my mixer out of the moving boxes [I am doing major renovation in the house]
Thank you!!
