How To Make Butter (and Buttermilk)
Step 4Butter sweet Butter
Butter sweet Butter
the cream will start to feel thicker as you shake it, making it MUCH harder to shake around, the easiest shaking method is to take the jar by the "neck" or the closest part to the lid, and shake downwards in a stabbing motion back and forth. Eventually the jar seems easier, and easier to shake, open the jar and peek inside, see butter? This is when the butter starts to seperate from the buttermilk, once you see the little clumps of butter inside the jar, begin to strain out the extra liquid (i recommend you save this, it is the buttermilk, and when home-made it tastes sweet, and is often used in baking i.e. pancakes,biscuits,etc; After straining the buttermilk you have the remeaining butter in the jar, just scoop it into a storage container and pat it down a bit, youll want to put it in the fridge to harden it a bit more so its easier to scoop and spread.
[the picture below is before straining out all of the buttermilk]
7 comments
Jan 20, 2008. 8:34 PMBTEQUINE says:
This is great,your instructions. You can also make butter from raw milk. No hormones or preservatives. There are some great sites that give the names of grade a raw milk dairys in most states.
I have only one correction. The liquid left after making butter is NOT buttermilk it is skim milk. Buttermilk is cultured. For info on buttermilk or general milk/butter/cheese/yogurt-yes you can make your own yogurt go to this site: http://biology.clc.uc.edu/fankhauser/Cheese/Cheese_course/Cheese_course.htm
great pictures.
Oct 26, 2011. 2:54 PMrallen13 says:
Thanks for the info. I have been wondering why the "buttermilk" is not like buttermilk you would buy.
Nov 25, 2009. 4:17 AMsolo.card says:
 Not quite...
Hormones / Preservatives shouldn't be in processed cream anyway. If the hormone is used at the farm, then it will be present in both raw and pastuerised milk. Good butter will only ever contain Salt as a preservative anyway, so making your own is no better than buying shop bought.
Feb 7, 2009. 8:23 PMtashabear says:
Sorry, no. Skim milk is what you get when you remove the cream from whole fresh milk. What is left after making butter is indeed buttermilk. Cultured buttermilk is different, as the website you mentioned clearly states: http://biology.clc.uc.edu/fankhauser/Cheese/BUTTERMILK.HTM
Jan 21, 2009. 7:54 PMmlm says:
I am interested how to make butter from raw milk. Can you please email me or reply here how to do it step by step? Thanks a lot for your help.
Feb 17, 2008. 11:21 PMtrippedbreaker says:
This is not entirely correct. "Buttermilk" actually refers to two different substances. "Traditional buttermilk" (the original definition) and "Cultured buttermilk". "Cultured buttermilk" is cultured:
http://en.wikipedia.org/wiki/Buttermilk
http://biology.clc.uc.edu/Fankhauser/Cheese/BUTTERMILK.HTM#old_fashioned_buttermilk
More information on making butter:
http://en.wikipedia.org/wiki/Churning_%28butter%29
http://www.motherearthnews.com/Real-Food/1978-03-01/How-to-Make-Fresh-Butter-without-a-separator-without-a-churn-and-without.aspx
http://webexhibits.org/butter/making.html
I've glanced quickly at a dozen other pages from a google search; they all refer to the liquid remnant as "buttermilk", whether the process involved souring the milk/cream first, or not.
Jun 13, 2011. 12:03 PMxgzan says:
READ THIS- VERY IMPORTANT
Butter will spoil faster when there is buttermilk in it, so it is important to remove as much as possible.
After you have poured off the buttermilk, put the butter in a bowl and work it with a spoon, have the bowl on an angle and drain off as much as you can. Now add some ice cold water and work it into the butter and this will draw out the remaining buttermilk. Drain off water and you are done.
I also start out by letting the heavy cream sit out in room temp. for 12 hours.
Doing this will start a chemical reaction that will help break down the casings that the fat cells are in. This will reduce the time it takes to release the butter. I only need to shake the jar for about 3 min, not 20.
Have fun.
Nov 24, 2009. 4:25 PMSpinWard says:
I love doing this. It just tastes wonderful! Great instuctable!
The times I've done this, I haven't had too strain it, if you just keep shaking and knocking the butter to the sides, It will form itself into almost a stick of butter by it'self. I usually pour out the milk and I can usually shake out the bar of butter.
Aug 20, 2009. 1:20 PMMetalcaster14 says:
One thing. If you don't wash out the butter, it will get mouldy quickly. Since butter is fat, water doesn't really do that much to it. You run the butter under the tap, while smashing the butter against the side. This gets any residual buttermilk out. You need to keep it under running water until the water coming off the butter is clear(no more buttermilk in butter)
Nov 24, 2009. 3:47 PMkfr1sby says:
Yep, I agree. I always wash my butter. I will not eat butter that hasn't been washed.
Jun 30, 2008. 3:36 PMLowEnergy says:
I haven't tried it, but from what I've read, an electric mixer can make this easier. Thanks for this instructable--the pictures help vs. other instructions I've seen.
Jan 22, 2009. 10:05 PMtubbychick3n says:
This is true, but it doesn't work very well in the blender if you start it as cream.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:theque
