Introduction: How to Make Chicken Braid
Picture of How to Make Chicken Braid
Are you looking for a filling and delicious main dish? Chicken braid is a flavorful and quite simple recipe that can feed 4 to 5 people. This recipe takes about 20 minutes to prepare and ready to serve in 40 minutes
Step 1: Assemble Ingredients and Cooking Materials
Picture of Assemble Ingredients and Cooking Materials
Ingredients
  • 2 cups of chopped, cooked chicken (2 chicken breasts)
  • 1 cup of fresh broccoli, chopped
  • 1/2 a red bell pepper, chopped
  • 1/2 a green bell pepper, chopped
  • 4 ounces of shredded cheddar cheese
  • 1/2 cup of mayonnaise
  • 2 (8 ounce) packages of refrigerated crescent rolls (flavor can very on preference)
  • 1/2 tablespoons of Garlic Salt
Equipment
  • Large dark baking sheet
  • Large mixing bowl
  • Hand operated chopper
  • Cutting board
Step 2: Prepare Veggies
Picture of Prepare Veggies
  1. Clean and wash broccoli, onion, and both bell peppers
  2. Cut both bell peppers and onion in half
  3. Then remove stems and seeds from bell peppers
  4. Remove outer most layer from the cut in half onion
  5. Cut broccoli florets off of its main stem
Step 3: Chop the Vegetables With the Chopper
Picture of Chop the Vegetables With the Chopper
  1. Take the clean and cut vegetables and use the hand operated chopper to chop them
  2. Once chopped add the chopped vegetables into the large mixing bowl
Step 4: Chop the Cooked Chicken With the Chopper
Picture of Chop the Cooked Chicken With the Chopper
  1. Warning: Make sure Chicken is fully cooked before using chopper and mixing with other ingredients
  2. You can cook the chicken either by microwave, baking, or using a frying pan
  3. Place the two chopped chicken breasts into large mixing bowl with chopped vegetables
Step 5: Non-chopped Ingredients
Picture of Non-chopped Ingredients
  1. Add ½ cup of mayo into large mixing bowl
  2. Then add the 4 ounces of Shredded Cheddar Cheese into the large mixing bowl (half a bag of cheese)
  3. Add ½ tablespoon into large mixing bowl
Step 6: Mix All of the Ingredients Together
Picture of Mix All of the Ingredients Together
Step 7: Dough Preperation
Picture of Dough Preperation
  1. Open up first crescent roll package and place dough on cooking sheet
  2. Open up second crescent roll package and place parallel to first package on cooking sheet
  3. Press together all of the crevices and parting lines in the dough
Step 8: Now Place Ingredient Mix in the Center of the Dough
Picture of Now Place Ingredient Mix in the Center of the Dough
Step 9: Braiding the Chicken
Picture of Braiding the Chicken
  1. Take a knife and cut lines perpendicular to the ingredient mixture centered on the dough, and have the cuts be spaced roughly 1 inch apart
  2. Once dough has been cut you will need to take the first cut piece of dough on the right side and twist it (braid) to the center of dough (Image 3 above)
  3. Then you will take the first cut piece of dough on the left side and braid it over top the right side piece in the center of braid. (Image 4 above)
  4. You will continue this till you get to the last pieces on each side, once you have reached this state you will remove the right side last piece of dough and place it in front of the braid (Images 5 and 6) to keep mixed ingredients inside of braid
  5. Now you will take the last cut piece of dough and place it over the back end of the braid. By doing this you will keep the mixed ingredients inside of the braid (Image 7)
Step 10: Place in Oven at 375 Degrees F (Warning: Oven Will Be Hot Be Careful When Placing in Oven)
Picture of Place in Oven at 375 Degrees F (Warning: Oven Will Be Hot Be Careful When Placing in Oven)
Step 11: Wait for 10-15 Minutes (or Until Crust Is Golden Brown)
Picture of Wait for 10-15 Minutes (or Until Crust Is Golden Brown)
  1. Warning: when removing chicken braid for oven it will be hot, so on this note make sure to be using the proper handling material.
  2. Turn off oven
  3. Let chicken braid sit for about 5 minutes once removed from the oven
Step 12: You Can Now Serve and Enjoy the Chicken Braid
Picture of You Can Now Serve and Enjoy the Chicken Braid
omasson (author)2015-06-25
You have an oven by Frigidaire ! The very brand that gave the name "frigo" that we still use in France instead of "refrigerateur". nice recipe by the way.
sobeeya (author)2015-06-18
i would like to use puff pastry
Dave max (author)2015-06-18
Wow its delicious .I had tried it but the braiding does not become perfect but it was tasty.
pbaxman (author)2015-06-17
It looks very tasty by all means but those are a few details that would make it pop.
You should start the braid the other direction and it will hide the loose ends. Also egg wash it before putting in oven
tomatoskins (author)2015-06-17
Oh my! This looks very tasty!
About This Instructable
2,195views
142favorites
License:
More by Blondy15:How To Make Chicken Braid
Add instructable to:
