For the Arm and Leg extensions I picked a Werewolf but this instructable will work for any costume you want to make! Ok I’m pretty sure “Creature Reacher” is a coined term by Rubies or Grand Heritage or some other main stream costume maker. We all know the costumes are pumped out in the masses and quality usually goes under the bus while the prices go directly to our wallet. In this instructable I plan to show you how to make the leg and arm extensions then finish the costume off Werewolf style! Hoooooooowwwwwwwl!!!!
As my halloween contest entry alot of work went into this costume please rate it if you feel its worthy of rating and please feel free to leave comments!! I love hearing what people have to say!! Thanks and I hope all you guys and gals in instructables land get a ton of use outta this instructable :-)
Remove these ads by
Signing UpStep 1Materials
Drywall Stilts (easily obtained on eBay)
Upholstery Foam (http://www.onlinefabricstore.net/foam-and-pillows/foam/upholstery-foam/upholstery-foam.aspx) Size, thickness & amount are up to you.
Contact Cement
Cardboard Tubes
Sissors / X-acto Knife
Duct Tape
Screws
For the complete Werewolf Costume you will need the following:
Wetsuit or Body Suit (I choose a wetsuit Ohio Halloweens are C-O-L-D, Brrrrr)
Long Pile Fur Material (Jo-Ann Fabrics) I picked Brown, it worked best for the werewolf.
Optional Latex Costume Head Hands and Feet
Contact Cement
Sissors/X-acto Knife
Duct Tape
With all the materials out of the way I will start with the Arm extensions and move forward from there. Let’s get started shall we?
Im ok w it the way it is.
This was a fun costume to make. I had a great time.
we should go trick or treating together. it would be sweet and scare children.
Anyone????
Instead of the wet suit try a divers skinsuit. They're made for warm water diving made of Lycra and significantly lighter, cooler, cheaper and easier to use.
Also while stilts are easy Digilegs are more accurate and not that much harder to make.
http://www.google.com/search?hl=en&source=hp&biw=1050&bih=861&q=digilegs&aq=f&aqi=g2g-m2&aql=&oq=&gs_rfai=CcSrdVFDATPDvIIPuMLOrsc0HAAAAqgQFT9B2HtE
http://www.kimgrahamstudios.com/gal-legs.html
As for the stilts, they were super easy to obtain. I will look into the Digilegs tho, not sure ive ever heard of them!
Thanks Again
Jeremey
