a better way to make a fire grenade is to use HTH/ glycerin method. HTH is sold in the pool supply as a chlorinator (also called "shock"). Glycerin can be found at almost any pharmacy section. KEEP THESE SEPARATE!!! until you are ready to start a fire. then place about 3-4 teaspoons of HTH in a zip-top bag, add about a teaspoon of glycerin, seal quickly and throw/drop/place. YOU HAVE ABOUT 15-30 SECONDS BEFORE THE REACTION WILL IGNITE. first you will notice the mixture bubbling and then it will turn brown, then black then WOOOOSH IT IGNITES LIKE THE FLICK OF A SWITCH.
this is one cool and helpful video. I saw people wanted it in word form so I helped out and did it for you so here it is. Make a Fire Starter Grenade This is a 'grenade type' fire starter. Just pull on the pin and throw it! It can also be used as a light or heat source. I AM NOT RESPONSIBLE FOR WHAT YOU DO WITH IT. Materials Foil, seran Wrap, Box of Matches, Scissors, Masking Tape, A Drinking Straw, a rubber band Paper Towels, Hot Glue Gun, Pliers, Lighter Fluid, and a Key Ring. Step 1 Cut the Straw in half Step 2 Take a piece of the tissue and close of one end of the straw with it using tape Step 3 Cut the striker off the box of matches Step 4 Stick the striker through the key ring and fold in half and trim it a little Step 5 Use a little tape to secure the key ring on the striker Step 6 Use the scissors to scrape the sulfur off the matches Step 7 Fill the straw with the sulfur powder from the match heads Step 8 Use glue gun to glue more matches in a circle to the top of the straw with the heads up and use the scissors to cut the head off one more match and put the head in the middle of the circle Step 9 Use glue gun to put the sulfurless match sticks around the bottom of the straw in a circle Step 10 Take a paper towel square and fold it to the length of the match/straw device and is just below the match heads. Then use the glue gun to glue it to the device and wrap it around the device then use the glue gun to seal it off Step 11 Take the saran wrap and cover the paper towel with one layer of it and use the glue gun to attach it Step 12 Use the glue gun to attach a piece of foil to the top of the device near the match heads Step 13 Take the rest of the powdered sulfur and pack it into the bottom of the device Step 14 Attach the striker (with the key ring taped to it) to the top of the device on the match heads with the rubber band Step 15 Take the lighter fluid and soak the bottom of the device with it. The paper towel will absorb it. Make sure to soak it enough so that is the whole paper towel is covered with it but not too much to where it is dripping wet and getting everywhere Step 16 (optional) I would suggest that if you would like to keep it for a longer period of time that after you soak the device with the lighter fluid, you use more plastic wrap to seal off the bottom of the device to prevent the lighter fluid from evaporating Step 17 You’re done. Now go out and test it SAFELY. !!!REMEMBER!!! I AM NOT RESPONSIBLE FOR WHAT YOU DO WITH THIS DEVICE. THIS WAS JUST AN INSTRUCTION ON HOW TO MAKE IT. USE AT YOUR OWN RISK AND DON’T GET CAUGHT.
It defeats the purpose It is time consuming waistfull and not compact and unreliable notgood for camping or survive pay 50cents for a pack of lowers you get 5 that do the same thing I want my 10min back
very interesting i prefer my zippo for lighting things but this makes a great ingnightor for something or throw it on a pile of wood covered in gasoline so you don't get burned
Great job! I use these alot for various reasons. I do have a couple of suggestions, though. 1. Use tin foil instead of plastic wrap, plastic releases toxic smoke upon burning. 2. Use your glue gun on LOW temp. ONLY! Great instructable with great results, you earned a 4.5!
Plus, I've got a video of another one of my firestarters, a little more explosive though, but it was designed for the same reason. The first part of the video is just a giant flame, the end is a little more suprising, though. http://www.youtube.com/watch?v=eBOcssDznew&feature=channel_page Cheers! ~F!nnster
Is there any alternatives for the straw, plastic wrap, or hot-glue. burning these at my camp is not aloud, and plus there bad for the environment. Great instructable by the way, 4 stars, though having typed directions would help a lot, thx
I think the matches are safety matches, otherwise you could use anything rough in the pin. The plastic wrap and aluminium foil are in fact optional, as the only part truly needed is the part that actually burns, although i suppose it makes it more "grenadey".
It seems to me that your fire grenade is more of a toxic grenade. I mean you using plastic wrap, hot glue, and aluminum foil (even though it won't burn much). If you ask me this grenade should only be for bomb fires. Also the grenade probably won't lite a log all that well without kindling (paper or small wood). And if your going to use kindling you might as well start a fire the right way.
Although I do like the idea for the starting mechanism.
Wow! this is a great video! I wouldn't soak it too much with the fluid though... you almost burned yourself it looked like. A longer delay would be better. Otherwise, great video and easy to follow instructions!
that's an awesome fire starter it makes it so easy to do light a fire it would be cool though if you did it with a book of matches also what is the name of the first song?
Very good video alot of effort put in and cool grenade/firestarter but if you used it as a grenade outdoors ued kinda set the place on fire hahah (5 outa 5)
Dude sweet video, love the 'ible too. Very informative and clear and great thing to make if I am going camping and have a hard time lighting wood. also what are the names of those songs you have playing in your video.
you should make match head-lighter fluid mixture, and soak the paper in it then wrap it up so the lighter fluid doesn't evaporate. OR i just thought of this, make the gun cotton fluid, soak the paper THEN make the grenade. also, how did you beak your arm>
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
No one said that this was only for starting fires.
Cheers!
~F!nnster
=) =-| =+@ =P
