How to Make Liquid Hand Sanitizer
Introduction: How to Make Liquid Hand Sanitizer
Hello there! Today I was putting salt into my hand sanitizer so it would be gritty. I needed something to get things off my hands better. Then, it turned to liquid after I shook it up... I thought, "What the heck did I just do?!?!" So I made another batch to show on the instructables world!
Step 1: Materials
You need a couple if materials------- 1. Germex 2. Salt. (I used kosher) 3. Funnel. 4. Small plastic bowl 5. Measuring spoons 6. Filter of some sort
Step 2: Mix It Up
Grab your measuring spoons and pull out the 1/4 teaspoon spoon. Fill it with kosher salt and pour into your germex. Watch as the salt slowly falls down, is it pretty? After the awing, shake the bottle vigorously! Act like you're homer and the germex is Bart Simpson! Shake for about 1 minute. Then let the salt fall down. (Yup, that's me shaking it in the picture)
Step 3: Assemble the Purifier
To assemble this purifier, just put your chosen filter on the bowl and pour in the mixture. Also, make sure the holes in your filter are small enough to block the salt.
Step 4: Purify!!!!!
Start to pour your liquid germex in the filter! A little salt in there will be fine, just not a lot. Do this until you get your desired water to salt ratio. Make sure to get the bottle clean of all salt and then pour the good solution in the original bottle.
Step 5: Thank You!
Thank you for viewing! If anybody knows what is happening. So anyways, SCIENCE! And, CLEANLINESS!!
    • Epilog Challenge 9
      Epilog Challenge 9
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    Okay! Thank you! It really sounded better than it turned out! I more did it because if the reaction than the sanitization.
    So now you need to rinse your hands off after using the no-rinse hand sanitizer because it left a salty film on your hands?
    I think the addition of salt breaks down the emulsified sanitizer. It breaks down the adhesion of the molecules that is holding the gel together. Throwing salt on the kitchen soap bubbles/foam in the sink after washing dishes makes it go down.
    and they add pumice to those garage hand no-water soap lotions for grit.
