How to Make Organic Insect Repellent
3,457
40
Published
Introduction: How to Make Organic Insect Repellent
Are you bitten in the summer? If so, you would want something organic. Not those chemically factory made repellents. You need something fresh.
Step 1: Materials
You will need: Lemongrass, lavender, thyme, and peppermint essential oils and cetaphile lotion or any untreated regular lotion. Most of these items can be found at moutainroseherbs.com or eden'sgarden.com. Then you'll need bottle with a working cap (preferably glass), a toothpick, a label, and a pen.
Step 2: Add Add Add
First add the lotion into the bottle then add the following per ounce. 2 drops lemongrass, 1drop thyme, lavender, and peppermint.
Step 3: Mixing Time!
Mix the solution together until even.
Step 4: Label and Finish
Write down the title(natural insect repellent lotion), the date and ingredients. Stick it on and you're finished!!!!
    • Oil Contest
      Oil Contest
    • Stick It! Contest
      Stick It! Contest
    • Water Contest
      Water Contest
    2 Discussions
    Sorry here is the link;  http://cfpub.epa.gov/oppref/insect/
    On the EPA website the effective natural repellents have a much higher concentration of essential oils than you are using. Check out the site http://cfpub.epa.gov/oppref/insect/
    It may not matter how effective your repellent is depending upon where you live. Here we have had several extremely serious cases of Dengue fever, and since I have other health issues I consider every mosquito bite to be potentially Fatal . I use Dr Bronner's peppermint soap to discourage insects a bit. It seems to help. But, I also use commercial repellants.
    I am glad that your mix works for you and it may help others in areas without dengue, malaria or west nile virus, etc.
