3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Make Paper Out Of Lint
Have you ever wondered what you can do with all that dryer lint that accumulates after you do your laundry?
In this Instructable I am going to show you how you can use lint to make paper.
Materials you will need:
Lint
Warm water
Wood frames (you can use two wood picture frames) or cardboard
Window screening
Scissors to cut the screening
Staple gun or hammer and nails
Tub
Blender
Fabric
Step 1First Soak the Lint
First Soak the Lint
The first step is to soak the lint in warm water for at least 30 minutes. This helps the lint to break down so that it's easier to blend during the next step. You should soak the lint in warm water until it becomes saturated and soft, the longer the better. If you have the time then soak the lint over night. You can also add other ingredients to be soaked in the water like shredded paper or leaves. Both paper and leaves will give the lint paper more body in the end.
25 comments
Jan 30, 2012. 10:51 AMgbunting says:
If you lay a sheet of netting or other textured surface under the paper and then iron the top surface of the paper, you will get an embossed paper with a glossy side. That's basically how they do it in the paper mills when they make envelope paper.
Aug 30, 2011. 8:34 AMavoss2 says:
Instead of squishing the water out with books, I just rolled it out with a rolling pin between a few towels. That worked well and fairly quickly and then I set the sheets of paper in the sun on a paper bag to dry. They stayed pretty flat that way. How were you able to get yours such a light colour? I bleached the crap out of my lint and still it is that nasty red/grey. If you have any tips on that please let me know!!
Apr 26, 2011. 2:10 PMrcovin says:
Thank you!
Feb 25, 2011. 7:15 PMTheJoshinator says:
I'd bet you could make the paper stronger and crisper by adding a bit of gelatinized cornstarch to it. Take 1 cup of water, mix in 2 teaspoons of cornstarch, and microwave it until it turns clear; add to slurry as necessary (as determined by experimentation) and you've got yourself some nicely starched paper.
Oct 29, 2007. 12:16 PMninjapants says:
This is pretty cool. How sturdy is the finished product? Could you write on it with a pen? Or would you have to add quite a bit of shredded paper to manage that?
Feb 23, 2008. 10:45 AMSaint_Awesome says:
I know that hemp paper can be bleached with ozone (as opposed to conventional dead-tree paper that they dye with chlorine, the source of the nasty rotten egg smell near papermills), maybe that could work here as well.
Nov 9, 2008. 6:39 AMevilad says:
Isn't ozone poisonous?
Jun 25, 2010. 6:11 PMWitchArachne says:
Ozone is pure oxygen, which, like all things, is poisonous in amounts more than the body can handle, which in this case isn't very much :)
Aug 18, 2008. 9:34 PMgreatpanda says:
And...adding smog to your paper will turn it white? How odd. You could try pumping O3 in from a standard spa ozonator if you really want, but I think the "art paper" look might be a little cheaper...
Jun 1, 2010. 7:54 PMfragmaster4 says:
I think Felt would be best for this :)
Jun 1, 2010. 7:51 PMfragmaster4 says:
They did this in the old days except they used cotton pulp. The resulting "stuff" was called Slurry ;)
Mar 18, 2010. 9:27 PMellie182 says:
hooray for lint.
Aug 25, 2009. 12:19 AMcutejuice says:
I made some paper mache stuff out of dryer lint recently and I found it quite disgusting. Maybe my dryer lint is hairier than ordinary folks'. I wasn't banking on the hairiness. It was a little too avant garde for me.
Jan 15, 2009. 12:54 AMchinchri says:
hi...ahm, when i saw this project..i decided to make it because it is really FANTASTIC but then,we didn't come up with a "paper".i knew there was something wrong with our ingredients..i just need some advices..where can i exactly get the lint?
Jan 8, 2009. 3:21 AMeyevegotstyl says:
I remember doing this experiment in middle school, it's really cool for homemade cards and the such, I added some glitter to the tub for an extra punch.
Jan 11, 2008. 12:14 PMcaramello says:
Great stuff! Just a quick question, how much lint do you need to make that piece of paper? A rough description (a fistful, etc) would do. Thanks!!
Nov 28, 2007. 3:06 PMliza.lu says:
That is so cool! I'm going to make that! I have a recipe for making dryer lint clay that I've been hanging on to for like 10 years and have still never done it, but I'll be sure to do this one.
Oct 29, 2007. 4:07 PMthreecheersfornick says:
How necessary is the blender step? Could I just knead it with my hands instead? 'Cause I don't really have a blender... Thank you!
Oct 30, 2007. 4:39 PMthreecheersfornick says:
Okay, thank you!
Oct 29, 2007. 9:34 PMrachel says:
Fantastic! When I was in 5th grade or so, a friend and I made some paper as a science project. It came out about like egg carton. I don't remember at all what we made it from, though!
Oct 29, 2007. 6:46 PMcrestind says:
Cool idea!
Oct 29, 2007. 10:01 AMcanida says:
Neat! What a fantastic reuse project.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:AshleyAmber
