How to Make Pine Needle Tea
Introduction: How to Make Pine Needle Tea
This delightful tea is great to drink because of its vitamin C (which is about 400 mg or more) and vitamin A ( which helps vision, skin and hair regeneration, and cell reproduction). Some of its creat uses help with you with cancer, a cold, scurvy, sclerosis, the flu, a digestive aid, an alternate for caffeine, weight loss, aging, urinary infections, kidney stone, and so much more (for more info see ).
Step 1: Tools and Ingredients
You will need:
A pot
Tuffs of WHITE PINE NEEDLES or other non lethal pine needles. (The white pine needles usually comes in tuff of 5, see picture)
A cutting board and a knife (optional)
And some thing to remove the needles from the tea
Step 2: Time to Make
Boil the water. While the water is boiling, separate the pine needles from the twigs cut off brown buds and chop into about 1/4" pieces. Once the water is at full boil remove from heat the put the pine needle pieces in the water and stir and let sit for five-ten minutes
Step 3: Serve
Use your strainer to remove any pine needles (if theres any left over use a spoon to get it out). If you want you can ad sugar. Serve and enjoy!
    • Science of Cooking
      Science of Cooking
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    It doesn't matter how much. I use a good handful of needles cut up without the little brown burrs which connect it to the tree. I chop them and use as much water as I want for tea or to make ahead of time. I add bits of dried orange. I boil it in the microwave and strain it. Using RAW honey to sweeten it turns it into a medicine which tastes like a very pleasant regular tea. My son had the flu last week, drank this every day for four or five days and felt great in no time. Raw honey has anti-biotic properties and the pine needles have more vitamin C than orange juice.
    The microwave will destroy the nutrients. You're not supposed to use boiling water... just below boiling, otherwise the heat will destroy the nutrients.
    boiling point of Vitamin C is 553 °C, much higher than the boiling
    point of water, which is 100°C. This makes sense that Vitamin C is not
    boiled off into the air when it is being cooked at the relatively low
    100°C, the temperature of boiling water. Instead, the Vitamin C is
    dissolved into the cooking water. If you drink the cooking water,
    you’re probably getting most of the Vitamin C. This is great news for
    boiling pine needles!
    You said white pine. I have yellow pine i was planing to do this with. I never heard of it being "lethal".
    About 2 cups of water and i grabbed 10 tuffs but you can use more, thanks for reading!
    hate to screw around and expermiment with something i probably might not like.
    Serving for two:
    how many cups of water?
    how many tufts of 5?
