loading
loading
How To Make Quick Simple Individual Pizzas
Featured
Picture of How To Make Quick Simple Individual Pizzas
Here is a recipe for Quick Simple Individual Pizza.
What you will need:
1. Oven
2. Aluminum Foil
3. Spray Oil
4. Pizza Cutter
Ingredients:
1. Flour Tortilla
2. Jar, Can or your very own home made Pizza Sauce
3. Toppings for Pizza (Your choice)
4. Spices if you just use tomato sauce like I do
5. Cheese. You can use store bought Cheese, or if you made your own Mozzarella from my recipe you can use that also. The recipe is at:
http://www.instructables.com/id/Great-Mozzarella-Cheese/
Step 1: Preheat the oven
Picture of Preheat the oven
Preheat your oven to 425 degrees so it will be hot when your ready to put the Pizza in.
Step 2: Starting the Pizza
Picture of Starting the Pizza
Tear off a piece of Aluminum Foil and place it on the counter Spray a little Oil on the Foil so the Pizza won't stick. Place your flour Tortilla on the Aluminum Foil.
Step 3: Adding Sauce
Picture of Adding Sauce
Spoon on whatever type of sauce you like. I use plain old Tomato Sauce and then spice it up the way I like it.
Step 4: Adding Cheese and Toppings
Picture of Adding Cheese and Toppings
Add your Cheese and toppings. Whatever you decide to use, chop it up small so it gets a chance to cook. If you use meat you might want to pre cook it a little bit and drain the excess fat off. You can put the toppings either under or on top of the cheese. (Although I guess if you put them under the cheese they probably wouldn't be called toppings. What would they be called???)
Step 5: Baking your Pizza
Picture of Baking your Pizza
Place your Pizza in the Pre heated oven. You can either place the Pizza and Aluminum Foil on a rack in your oven or just put the Pizza on a Pizza Pan or Pizza Stone. I use the foil so I can just throw it out when finished. The Pizza should bake in about 10 to 15 minutes depending on how brown you like your cheese.
Step 6: Cut and Enjoy
Picture of Cut and Enjoy
Cut the Pizza up and put it on a plate. Enjoy!!! You can make up a bunch of these at one time and freeze them to bake later. These are also great for parties where everyone can put on their own toppings and everyone gets involved.
I hope you enjoyed this Instructable.
Mike
i think i am going to try to use 2 flower tortilla and put some cheese in between them for a cheesy bottom
good idea..i made it....yummy
graywoulf3 years ago
Great "Ible" mikemwa ! I have made pizza like this in the past as well but I thought I would pass along one of my ideas and that is making the crust double layered and spreading a layer of cheese in between the two tortilla layers to create a stuffed crust style pizza. I have even added spices like oregano or minced garlic as well. Another variation is to use Monterey Jack cheese and taco style toppings. I guess you could call it a quesadilla crust pizza in a way. So many ideas to be explored and so many people to think them up. Bon Appetit !
I think they'd still be toppings. I mean, they're only called that because they go on .top. of a pizza. Cheese is also a topping, even if it's not on the very top, right? Or at least it's considered a topping around here ._.
or maybe fixins :)
twisteddman4 years ago
I just discovered the ability to use tortillas for pizza on my own about 6 months ago. It is a great way to make some quick pizza. If you are on any kind of low carb diet you can make these with no sugar pizza suace and low carb tortillas. I also have found that placeing the pizza directly on the oven rack makes them turn out much better. The tortilla becomes crisp like pizza crust in about 20 minutes.
miky195224 years ago
would they be called stuffings
blodefood7 years ago
If you used a cookie sheet or pizza pan, you would not have to throw out foil. Washing up is minimal. Great idea for a quick pizza!
I put foil on the LOWER rack in the oven, and put the pizzas directly on the UPPER rack, with the upper placed at about the middle of the oven.  The crust gets nice and crispy on the bottom that way, and the lower foil is there just to catch any cheese drips that might escape.  I only have to change the foil every 3-4 times.  Saves on foil AND cleanup, and the pizzas are nice and crunchy.
idontcare6 years ago
"Although I guess if you put them under the cheese they probably wouldn't be called toppings. What would they be called???"-mikemwa They would probably be called middles.
They're still toppings, they're on top of the crust!
underlings?
that would work too
mikemwa (author)  idontcare6 years ago
Good point !!!!
the crowing5 years ago
I have been making tortilla pizzas for years and i love them. The only thing i do different is i lightly oil the bottoms and cook them in a skillet on medium heat until the tortilla is crispy. They come out just as good as the oven IMO and they cook much faster. Nice instructable.
Kaiven6 years ago
Hopefully, my lunch for today.
bdubu6 years ago
Nice instructable. Thanks! I just recently discovered tortilla pizzas myself about 4 months ago. In fact, I had a couple for lunch today... Mmmm!
T3hpw9ag3 6 years ago
i just made this a week ago, i have been doing it for a while but never thought to make an instructable on it, oh well, nice job anyway
BlueGasMask6 years ago
When you say 425 degrees, do you mean Celsius or Fahrenheit?
mikemwa (author)  BlueGasMask6 years ago
It is Fahrenheit. This should help.<br/><br/>225 Fahrenheit = 110 Celsius <br/>250 Fahrenheit = 130 Celsius <br/>275 Fahrenheit = 140 Celsius <br/>300 Fahrenheit = 150 Celsius <br/>325 Fahrenheit = 170 Celsius <br/>350 Fahrenheit = 180 Celsius <br/>375 Fahrenheit = 190 Celsius <br/>400 Fahrenheit = 200 Celsius <br/>425 Fahrenheit = 220 Celsius <br/>450 Fahrenheit = 230 Celsius <br/>475 Fahrenheit = 240 Celsius <br/>500 Fahrenheit = 250 Celsius <br/>
Pitas work, as well. Good post. You should tell us what you put in your sauce.
PetervG7 years ago
What do you heat it to?
mikemwa (author)  PetervG7 years ago
OOOPPS. Kinda left that out. Pre heat to around 425 degrees. Thanks for pointing that out.
theRIAA PetervG7 years ago
golden brown. not all things in life have to be perfect.
tomlevine17 years ago
yum...!
Cool! Great Instructable! Looks Tasty! Thanks Joe
