How to Make Really Simple Sumo Bot
Published
Introduction: How to Make Really Simple Sumo Bot
You need two very low rpm motors a battery wire something to hold it together(mecano works well) a soldering iron solder hot glue gun
Step 1:
Solder the battery wire to the one motor.
Solder wire from one point of motor to one point of the other motor.
Just follow the diagram and make sure there are two prongs at the front
Step 2:
Glue the motors to each other with the wheels facing in opposite directions
Make a position for the 9v battery to sit on top of the sumo bot
Step 3:
The reason this works is because of the base which is about 30cm wide
The middle was made from aluminium foil and the 5cm ring around it was just paper
Step 4:
I made it a long time ago so it's kind of falling apart.
    • Planter Challenge
      Planter Challenge
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
