Introduction: How to Make Simple Stacking Plates for Design
Picture of How to Make Simple Stacking Plates for Design
I needed to figure something out for my mom because she design one wall of the house and dose not have anything to put things on to raise them in the back so I thought of these.
Step 1: The First Cylinder
Picture of The First Cylinder
Make the first Cylinder radius of 7.5 cm and a height of 5 cm
Step 2: The Inside Bit
Picture of The Inside Bit
now make another Cylinder with a radius of 7 cm and a height of 5 cm
Step 3: Placement
Picture of Placement
Set both cylinders to 0,0,0. Now they should be inside each other.
Step 4: Copy
Picture of Copy
first copy the middle and make a copy. Then move the copy out of the way.
Step 5: Boolean
Picture of Boolean
Select the biggest cylinder then go to compound objects and select Boolean and subtract the one in the middle. When you are done you will have a ring.
Step 6: Filling the Space
Picture of Filling the Space
now select the copy and set it to 0,0,0. It should fill the space perfectly.
Step 7: Raising It
Picture of Raising It
click on the center cylinder and raise it up 1 cm
Step 8: Now Putting Them Together
Picture of Now Putting Them Together
click on one of the cylinders and then go to the Boolean tool again but this time you will want to union them together. and now you have a 3D model of simple stacking blocks.
amandaghassaei (author)2012-10-22
nice, simple technique for creating these. what do you plan to make these out of?
ABS plastic
About This Instructable
551views
0favorites
License:
More by darth marvin:A New Nut and BoltHow To Make Simple Stacking Plates for DesignOutdoors small tools for making other tools kit
Add instructable to:
