iImage Information
A quick and simple striping device that can be pulled by hand or attached to push or riding mowers.
Step 1PVC pipe
iImage Information
Get a length of PVC pipe (any other type will work, but PVC is what I had) and cut it so that the length is equal to the width that you want your stripes to be. If you are using the striper behind a mower and not by hand, cut it so that it is about 1-3 inches shorter than the cutting diameter. Cut it however long you want if you do not want to attach it to a mower and want to pull it by hand or without the mower blades on. Sand the rough bit around the outside of the cut so that it is smooth.
