How To Make Stripes in Your Grass
 by baseballer
A quick and simple striping device that can be pulled by hand or attached to push or riding mowers.
Step 1: PVC pipe
Get a length of PVC pipe (any other type will work, but PVC is what I had) and cut it so that the length is equal to the width that you want your stripes to be. If you are using the striper behind a mower and not by hand, cut it so that it is about 1-3 inches shorter than the cutting diameter. Cut it however long you want if you do not want to attach it to a mower and want to pull it by hand or without the mower blades on. Sand the rough bit around the outside of the cut so that it is smooth.
pancho del rancho says: Aug 21, 2009. 5:48 PM
sweet
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
