loading
If you’ve creativity and vision, there’s no reason you can’t make the best invitations yourself. Apart from saving money, you get to add a personal touch. Hand-crafted invites will allow you to put as much information as desired. Here’s a process you can follow to make the best DIY invitations.
Step 1: Design and template
The first thing you would need is a design for the theme. If you’re good with designing through softwares, you can use InDesign, or any other software you’re familiar with. However, avoid using Microsoft Word. The best invitation is going to require a modern design. The modern design focuses more on the content, and there’s a lot of white space. Consider adding some photos as well.
If you can’t use design softwares, custom designs are available for different themes on websites like www.invitationbox.com. For the template, you can go for a single paper or a folding card. For the size, you can choose 5 by 7 inches, 4.1 by 5.25 inches or 4 by 9 inches.
Thanks for sharing! These are very pretty!
About This Instructable
1,585views
7favorites
License:
More by agreen1019:7 Steps to a Backyard Ice Rink DIY: Making Your Own Text Book Covers Changing the O-Ring on an Engine Fuel Injector
Add instructable to:
