How to Make the Delta-Fighter Paper Plane
Published
Introduction: How to Make the Delta-Fighter Paper Plane
The Delta-Fighter is not only a cool and sleek paper airplane, it is also very fast and agile which allows it to do maneuvers like loops, rolls, and banked turns.
This is an instructable entry for the Paper Airplane Challenge 1
Step 1: Materials
1 Piece of 8.5 x 11 inch Paper
Ruler
Tape
Pencil
Step 2: Length-wise Fold
Fold the paper in half Length-wise to create a center-line, then unfold.
Step 3: X-Fold
Take the right or left corner to the paper and fold it to the length of the opposite side. Then repeat with the inverse arrangement. Flip, then pull the front down to make a doubled layer. Flip back over, then using all of the pre-folds made earlier, start to remake the X Fold allowing the paper to collapse into a triangle.
Step 4: Starting the Wings
Lift one layer of the triangle over to the other side. Fold the longest flap into the center line, then fold the flap on the other side in. Now fold the shortest flap over and repeat the whole thing to the other side.
Step 5: Shaping the Wings
fold one inside flap over and mark 2 1/4 in. from the tip of the plane and at the end of the leading edge. fold the flap out using these marks. Now mark 3/8 in. from the tip of the wing, and 1 3/8 in. from the tip of the plane. make a fold from the 1 3/8 in. mark and so the leading edge of the flap is at the wingtip mark. repeat to the other side.
Step 6: Locking the Wings
Step 7: Finishing the Wings
fold the plane in half along the centerline. mark 2 in. from the front, and mark 3/4 in. in the back. mountain fold between the two marks, then repeat to the other side (sink fold). mark 3/8 in. in the upper back part of the fuselage. fold from this mark to the front of the plane to make 1 wing. repeat to the other side.
Step 8: Creating the Rudder
mark 1 3/4 in. from the top point of the fuselage. then pull up the rudder so the front is touching the mark.
Step 9: Taping the Fuselage and Wings
apply tape where shown
Step 10: Rounding the Fuselage
use your fingers to slowly warp and bend the fuselage to round it out. it is important that you do this step!
Step 11: How to Fly
this plane does require about a 3/16 in. deflection on the elevator in order to fly.
if the plane tends to drift to the left, warp the back of the rudder to the right slightly. keep tweaking it until it can sustain forward flight.
if the plane tends to rapidly climb, loose airspeed, then fall, warp the elevator down slightly. again, keep tweaking it until it can sustain forward flight.
if the plane tends to dive rapidly then crash, warp the elevator up slightly. AGAIN, keep tweaking it until it can sustain forward flight.
Step 12: (OPTIONAL) Missiles
you will need:
4 standard toothpicks
tape
tape the 4 toothpicks to the forward part of the wing, 2 where the wing meets the fuselage, and 2 about 1 in. out from the the other ones.
    • Planter Challenge
      Planter Challenge
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    9 Comments
    tried to put the picture on; i am confused on how to do it.
    have you already uploaded it to your library?
    i cant open .exe files on my computer (i use mac). Just PM me with a link to the photo of the plane in your image library. i find this to be the easiest way to share photos
    Ignore the LDD stuff, I messed up.
