How To Make The Leopard Paper Airplane by OrigamiAirEnforcer
Step 1: Materials
Required:
1 Piece of 8.5 by 11 inch paper
Tape
Scissors
Optional:
Pencil
Step 2: Length And Corner Folding
First, fold your paper in half along its length. Then pull the corners of the paper in.
Step 3: Pull The Nose Down And Begin To Cut
Pull the paper down along the bottom of the corner folds. Then fold the paper up with the "dirty" side outside. Cut a 1 by 1 inch square out of the front (the side of the paper where you folded the nose down) and out from the center of the paper.
Step 4: Corner And Security Folding
Now that the initial cutting is over, pull the corners in again. Then pull the small triangle up through the 2 by 1 inch hole and crease it down to make the security fold.
Step 5: Fold The Wings And Cut The Vertical Fins
Fold your Leopard's wings down from 3/4 of an inch above the bottom of the fuselage. Whilst the wings are both folded down, make a cut that reaches in 0.75 inches into the wing at a thirty degree angle towards the front of the aircraft. Then raise one of the wings and make a 3/4 of an inch cut into the fuselage at a thirty degree angle towards the nose of the airplane.
theswordninja561 says: Jan 28, 2011. 6:40 PM
3 words...ONE...OF ...THE... BEST .PLANES. EVER!!! (crap that's 6)
heavyfire88 says: Mar 7, 2011. 10:17 AM
Mine doesnt fly -.- :D
OrigamiAirEnforcer (author) says: Mar 7, 2011. 11:21 AM
What happens to it? Spins? Spirals? Dives? To help, I kinda need more specifics. :/
tiger 777 says: Aug 16, 2011. 9:43 PM
this is the best design yet.mine is super fast
OrigamiAirEnforcer (author) says: Aug 16, 2011. 9:47 PM
Thank you! You may want to explore some of my even newer designs too! :)
ybhatt says: Aug 14, 2011. 6:30 AM
yes
aarij007 says: May 13, 2011. 8:18 AM
Can you make the steps more descriptive?
OrigamiAirEnforcer (author) says: May 13, 2011. 1:47 PM
There isn't much to describe on this step... :/
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
