How to Make the Shriek Paper Airplane
Introduction: How to Make the Shriek Paper Airplane
This fast, long range plane called the Shriek is an agile follow-up to the very popular Spectre paper airplane.
TAA USAF Designation: A62-1
Step 1: Materials
1 Piece of 8.5 by 11 inch paper
Step 2: Simple Folding
Begin by folding your paper in half along its length. Then pull the corner into the center. Repeat on the other side.
Step 3: More Corner Folding
Pull the nose down along the bottom of the corner folds. After completing that aspect, pull the corners in once again. Now fold the plane in half along its center.
Step 4: Preparing the Trailing Edges
While the "dirty" side (the one with the corner folds and airfoil on it) is on the outside of the half fold. pull the rear wingtip corners to the airfoil's rear. Repeat this on the other side.
Step 5: Cut the Trailing Edge
Now fold your plane up in half with the airfoil in between the two sides. Then cut along the crease you previously made. Cut off the scraps that come from the trailing corner and recycle them.
Step 6: Wing and Winglet Folding
Make each wing by folding own all but one inch of each side of the paper. Once each wing is folded, fold the winglets up 1 inch in from the wingtip. Once you've established a crease, fold the winglet back down under the wing along the crease.
Step 7: Taping
Taping your Shriek is very easy. Tape it at the front and back of its fuselage.
Step 8: Flight
The Shriek is forgiving as fast planes go. With a medium speed launch requirement, it is fairly easy to throw and is also fairly resistant to winds. It also has good long range characteristics.
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    • Science of Cooking
      Science of Cooking
    Very slow to make but flies well and stays in shape (most of the time) when it crashes
