How to Make the Turbo Ghost Paper Airplane
1,149
Posted
Introduction: How to Make the Turbo Ghost Paper Airplane
Fast, long range and stealthy, the Turbo Ghost paper airplane is a more capable successor to the popular but outdated Ghost. The Turbo Ghost is sturdier, faster and capable of flying further than the original Ghost and is no less stealthy or shapely either. This aircraft is based in spirit upon "the Stealth" seen here, but the two have little in common.
TAA USAF Designation: A187-1
Step 1: Materials
Required:
1 Piece of 8.5 by 11 inch Paper
Tape
Ruler
Scissors
Pencil
Step 2: Length and Corner Folding
Take your paper and fold it along its length. Then pull the corners in and fold them into the center.
Step 3: Nose and Security Folding
Pull the nose down along the bottom of the corner folds. Then pull the corners into the center. Then open them and fold their inner corners up to the crease. Then fold them back along the crease. Then pull the small triangle that remains over the two folds.
Step 4: Marking and Making the Trailing Edge
Fold the airplane in half along its center fold. Measure 0.75 inches above the center fold and make a mark (Mark A). From this mark, measure a further 0.5 inches upward along the trailing edge and make a mark (Mark B). From this point, measure 0.75 and 1.5 inches upward and make marks at each (Marks C and D). From the 0.75 inch point, measure 1 inch perpendicular to the trailing edge and make a mark. From this mark, make lines to the marks B and D. Once you have done this, measure 0.5 inches back from the leading edge at the wingtip and make a mark (Mark E). Then connect marks D and E with a line. Measure 0.75 inches in from the wingtip along the trailing edge and then measure perpendicular to trailing edge and make a dotted line. When this has been completed cut along all solid lines as shown. You may discard the pieces cut off by this.
Step 5: Wing and Winglet Folding; Taping
Fold the wings down 0.75 inches above the center fold (at Mark A). Then fold the wingtips down along the dotted line made previously. Apply tape to the nose, back and across the wing root near the back.
Step 6: Flight
Similar to the original Ghost, the Turbo Ghost requires a moderately fast launch at a negative or neutral attitude. If your Turbo Ghost dives, bend the outer wing sections' trailing edges very slightly upward. Some test flights may be necessary to set the trim properly. Additional applicable surfaces include slats, flaps, flaperons, elevators, ailerons, elevons and rudders. Enjoy!
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
